Steering Wheel Volume Control Fail - Maybe
Old Mar 14, 2012 | 07:23 AM
W7PSK's Avatar
W7PSK
Veteran: Navy
Before I call the dealer, just wonder if there is something I can check. Ive lost the Volume up portion of the steering wheel volume control. Have not spilled anything on it that I know of. Volume down and all the other buttons work fine.
Anyone had one go ?
Old Mar 14, 2012 | 11:07 AM
W7PSK's Avatar
W7PSK
Veteran: Navy
Cue Eerie Twilite zone music.
On my hour commute home yesterday I had turned the radio off and on many times hoping that would reset it.
Started truck and heading out on the freeway not thinking I just turned the radio up and lo and behold it worked.
Now what ?
Old Mar 14, 2012 | 11:21 AM
Adobe 11SD's Avatar
Adobe 11SD
Mine quits working sometimes. No rhyme or reason. I have to turn the key off and back on to get it to work again.
It started after I installed the new speakers.
Old Mar 14, 2012 | 12:54 PM
W7PSK's Avatar
W7PSK
Veteran: Navy
Ok so Im not crazy,
Well I have not done anything to the truck except service and driving it
so I guess i will have to wait
Old Mar 14, 2012 | 05:27 PM
KC8QVO's Avatar
KC8QVO
I've had the same issue with my cruse control. It has happened about 4 times since I got the truck. The cruse icon on the dash will go to green but it won't engage (truck slows down when I let off the accelerator). It always resets with a cycle of the key.
Old Mar 14, 2012 | 07:16 PM
Cold One's Avatar
Cold One
The stering wheel controls on my last 2011 f250 would sometimes quit working while driving and always reset on the next startup. One of the many reasons I traded!
Old Mar 21, 2012 | 08:46 PM
gelato583's Avatar
gelato583
Same thing happened to me. I was under warranty and the dealership put in a new switch. Seems to b good now
Old Mar 21, 2012 | 11:00 PM
parkland's Avatar
parkland
DO NOT SPRAY ELECTRICAL CONTACT CLEANER IN IT.
It melts the plastic badly.
As smart of an idea as it might sound like, DO NOT DO IT.
Old Mar 22, 2012 | 12:23 AM
TRENT310's Avatar
TRENT310
Who's got a wiring diagram? Are the keypads just resistance grids with different resistances for each button? That saves on wiring, so I'm guessing that's what is used for those controls. That would be a good test to identify or rule out one side.
Old Mar 22, 2012 | 10:35 AM
greggara's Avatar
greggara
This has happened to me several times since I have had my 11. Always works after a restart.
Masterofyard
May 3, 2017 04:16 PM
BCM
Dec 5, 2011 10:31 PM
rjstat
Nov 14, 2006 02:42 PM
Shake-N-Bake
Oct 10, 2003 08:55 PM
