Sponsored by: Real Truck
HELP! Transmission light question
Old May 13, 2014 | 11:04 AM
NorEasterMA's Avatar
NorEasterMA
As I reached the end of my hour long highway commute today, I gave my truck a little more gas to hold my speed up the hill to my exit and as I did the truck downshifted. As it downshifted, my tranny light on the dash came on and stayed on. I drove the mile or so from exit to my parking lot and here it sits. Drives fine, shifts fine, and doesn't smell. Need some advice if anyone's got any, it needs to be able to make that hour long drive home Thursday night. Is it okay to drive? Is there something I need to do? It's an 06 F-250 5.4. Thanks in advance to anyone who can provide any insight...
Old May 13, 2014 | 11:25 AM
je5's Avatar
je5
Have a code reader or scanner put on it to give me the code.
Many auto parts stores will do that for you.
Old May 13, 2014 | 11:30 AM
NorEasterMA
Update: tranny light off check engine light on. En route to twilight zone now. Also noticed something (looks like a small hose) that is hanging loosely in the engine bay above and to the passenger side of the motor. Will post a picture shortly.
Old May 13, 2014 | 11:34 AM
NorEasterMA
Okay so I've got an emissions thing...really not sure what the deal was with the tranny. My codes are PO171 and PO174. Thinking I'll try to clean out the MAF and throttle body? Will have pic posted of the "loose hose" shortly. Thanks
Old May 13, 2014 | 12:01 PM
NorEasterMA
So here's the photo, the thing I'm holding looks like it should go somewhere, but it doesn't. So that's it, those two codes and this issue here. Anything? Thanks
Old May 13, 2014 | 12:03 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Vac line for the heater control valve. Plug it back into the nipple that is right above and between your thumb and the end of the hose in your picture.
je5's Avatar
je5
Plug it in where your index finger is at.
Old May 13, 2014 | 12:06 PM
je5's Avatar
je5
It is running too lean because of the vacuum leak.
Also check the larger hose at the rear of the plenum
that goes to the PCV valve at the valve cover.
Old May 13, 2014 | 12:36 PM
NorEasterMA
That is sort of what I was thinking in terms of where it went. I'll pop it back in there and check the larger hose as well while I'm there. The roads I commute on aren't the best, so I'm sure the hose worked itself loose.
Thanks for all the help guys, it's much appreciated!
Old May 14, 2014 | 06:17 AM
CPaulsen's Avatar
CPaulsen
If you got enough hose.....just trim a little of the end and slide it back over that nipple.
mattyf150
2015 - 2020 F150
Jul 18, 2016 07:36 PM
dirtsnow
Nov 15, 2007 01:36 AM
pitrow
Jul 16, 2007 03:59 PM
ltmerrill
Apr 12, 2005 11:29 PM
Diggr
1983 - 2012 Ranger & B-Series
Mar 2, 2003 05:35 PM
