Slow Start
Old May 12, 2014 | 10:01 PM
1999SuperDutyStroke's Avatar
1999SuperDutyStroke
Slow Start
Just throwing out a question for all the SD gurus and you know who you are!!! I have gone thru 3 starters in 17 months, 2 remans and 1 hi torque brand new. they will work fine for a few months then slowly start becoming more and more sluggish. Then suddenly the passenger side battery will be completely dead. My question is this, is the starter powered by the passenger side battery? And would the failing starter cause a drain on that battery? I hope my question isn't too vague!
Old May 12, 2014 | 10:30 PM
crop harvester's Avatar
crop harvester
low voltage to the starter,is a common problem due to discharged or bad batteries,dirty battery cable connections,bad battery cables,draw on batteries which cause low voltage starts,alternator can cause a draw if has a bad diode.watch voltage drop in batteries while sitting overnite & over weekend.
User 93024
2004 - 2008 F150
Nov 24, 2013 08:55 AM
dylansf23
62
Oct 22, 2013 08:01 AM
rollinblackcloud
Jun 27, 2012 02:16 PM
Bobtailfan
Electrical Systems/Wiring
Jun 21, 2012 01:48 AM
Yukon
Sep 13, 2007 02:06 PM
