Sponsored by: Real Truck
Instrument cluster not working
Old May 12, 2014 | 08:51 PM
kevin12's Avatar
kevin12
Hey guys I'm having a little problem with my F350. I've had it for about a month now and the cluster had no problems or whatsoever. Then, I drove it today and I noticed that the instrument cluster is not working at all. The lights work, but the gauges wouldn't move. When I turn the key before starting it the chime is beeping faster than it usually did before and it wouldn't shut off unless I close the door. It also only indicates the airbag and battery light. I checked all the fuses and they were good especially #15 or #16 can't remember it right now.
I don't know if its related, but this past saturday I was messing with the overhead instrument cluster for the gas milage and all that. I soldered some of the relays back on and that was it. I started the truck after I did all that, but everything was still working.
It's been bugging me all day today.
Any suggestions would help!
Old May 12, 2014 | 10:49 PM
bthr22's Avatar
bthr22
I had a similar problem when I got my '00 F250. Turned out to be the fuse for the overdrive button on the shifter. I don't remember what fuse number it was, but that fixed it.
Old May 13, 2014 | 07:24 AM
projectSHO89's Avatar
projectSHO89
Check Fuse F19 under the dash. It runs the cluster, the overhead console, and the O/D Cancel switch. See owner's manual.
Since you were soldering in the overhead console, I'd suspect a fault there first. Under typical day-to-day failures, chafed wires where they enter the shift lever tube is the most common problem.
Old May 13, 2014 | 06:59 PM
kevin12's Avatar
kevin12
Thanks! For some reason I overlooked fuse #19. Thanks for the help brother.
86stepsideF150
16
Oct 9, 2010 11:06 AM
silverstreak70
Sep 28, 2009 11:21 PM
callman
1997 - 2003 F150
Jun 2, 2008 04:01 PM
Jay Fletcher
Apr 29, 2003 12:00 PM
