SRS/Airbag code question
Old May 12, 2014 | 07:08 PM
JJ76014's Avatar
JJ76014
Question SRS/Airbag code question
I have suddenly acquired a new value added feature to my X. An airbag warning light flashing code 18. Through the research I have found it is either a pretensioner issue or a short. Would like to know for sure what it is, if anyone could help.
It is a 2001 LTD 5.4L. Any info would be appreciated.
Thanks
Old May 15, 2014 | 12:07 PM
BassFantasizer's Avatar
BassFantasizer
As far as I can tell, ALL warning codes that you'll ever actually see are either a pretensioner issue or a short. My Ex flashes 33.
Be careful with your research. There is conflicting documentation.
Old May 15, 2014 | 12:13 PM
BassFantasizer
That sounded a bit catty, huh? Apologies.....
The codes are documented in another thread:
https://www.ford-trucks.com/forums/4...ml#post3398361
I've seen documentation that contradicts that, but let's go with it for now.
A code 18 says that there's a short in the circuit. Disconnect the pretensioner plug at the seat belt base and see if the code changes. If not, the short is further up the circuit. If it does change, the issue is in the plug or pretensioner.
~Bass
Old May 15, 2014 | 12:39 PM
jpr38057's Avatar
jpr38057
Flash code 18 could either be Passenger Pretensioner Circuit Shorted to Battery or Ignition or Passenger Pretensioner Circuit Shorted to Ground. There are actually two different codes that if done at the dealer would specify if the short was to ground or battery.
Old May 15, 2014 | 07:08 PM
JJ76014's Avatar
JJ76014
Thanks guys. And don't worry about me taking things wrong in text form. I have very thick skin. I know that there are half a dozen different definitions on srs codes, which is why I thought I would throw it out there. I knew that I could not possibly be the only one that has ran into this. So I thought I would ask the experts.
Once again, thanks for the input. Time to pull out the multimeter and start tracing wires.
Old May 17, 2014 | 07:56 PM
JJ76014's Avatar
JJ76014
Just an update. Found the problem. When I pulled out the carpet to give it a good cleaning upon putting everything back in place I got a wire pinched. I traced wiring for a good hour until I found it. Everything is good once more.
jmana
Escape & Escape Hybrid
Dec 22, 2012 08:10 AM
fixnair
Electrical Systems/Wiring
Feb 25, 2009 09:16 AM
woolie74
1983 - 2012 Ranger & B-Series
Apr 7, 2006 08:43 PM
n1hle
3.8 & 4.2L V6
Mar 13, 2004 08:40 PM
