Alternator bolt snapped off
Old May 12, 2014 | 06:34 PM
Max159's Avatar
Max159
My alternator top bolt snapped off and now a small chunk is stuck in the engine block and is flush with it so i cant get it out with pliers i drive a 86 f250 with the 351w any help to getting it out would be great thanks in adavnce.
Old May 12, 2014 | 11:20 PM
Beechkid's Avatar
Beechkid
Weld a nut on the end and then back it out.
Old May 12, 2014 | 11:29 PM
Max159's Avatar
Max159
Thank you
I didn't think of that thank you, worked like a dream
Old May 13, 2014 | 08:32 PM
baddad457's Avatar
baddad457
Yea, the welded nut works nearly everytime. Just sometimes you gotta weld a few nuts before getting one to stick. Then make sure the nut cools sufficiently before trying to unscrew it. Put some antisieze compound one the bolt threads and the shank and you'll never have that problem again. (unless you're just getting to "happy" with the wrenches)
Old May 15, 2014 | 10:13 AM
daveengelson's Avatar
daveengelson
Welcome to FTE!! Not an authority, seems trying to weld another bolt onto a shaft flush with the block could be problematic? I would proby start try using an easy-out; use a punch to set the mark then pre-drill with appropriate size bit and follow up with appropriate size easy-out.
Old May 15, 2014 | 10:24 AM
baddad457's Avatar
baddad457
It's not hard at all. The weld will not stick to the cast iron block, only the steel bolt. The trick is to hold the nut in place when working alone. I hold the nut in a box end wrench then nail the center with my Mig gun til the hole is filled. Once that's done, you let the weld and nut cool til it turns grey, then unscrew it. Like I said before, sometimes you may have to do it a few times before the weld holds, but once it does, the bolt will unscrew without effort. The weld allows you to catch the bolt, the extreme heat loosens the threads. This is far more effective than trying to drill the bolt and chance breaking an E-Z out in the hole. The E-Z out tends to expand the bolt as you try to unscrew it, the weld exerts no pressure on the threads. Once you've tried it, you'll toss those E-Z outs in the scrap bin.
Old May 15, 2014 | 10:53 AM
daveengelson
Appreciate the information, thank you, yes using an E-Z out can be a pain in the backside.
Superblue400
33
Jan 31, 2026 12:13 PM
timmygyu
1978 - 1996 Big Bronco
Jan 1, 2011 09:37 AM
burninrubber2416
Jul 17, 2009 07:21 AM
mattystowe
Jun 23, 2009 11:48 AM
halfinch
Dec 17, 2008 02:23 PM
