Climate Control Vacuum Lines
Old May 11, 2014 | 04:48 PM
jfmaz's Avatar
jfmaz
Hi,
97 F350 CC 4x4 7.5L
A rodent chewed a couple of holes in a vacuum line from my climate control to the outside air motor where the line is exposed in the engine compartment.
I have looked around, and no one seems to have anything to repair it with, all too big, no fittings.
The line is a soft line, not one of the hard vacuum lines.
I was at NAPA yesterday looking for it, and in the parking lot with the hood open was an 89 Bronco. It had the exact same line in it to the outside air motor, a white vinyl looking line (with no rodent teeth marks!) so there must be alot of them out there, but I can't find a place to get it.
Anyone have experience and a trick to splice in a larger hose or something? or know where to buy new?
Old May 11, 2014 | 04:53 PM
subford's Avatar
subford
Most just bridge the gap with a rubber vacuum line and use small zip ties on each end.
Old May 11, 2014 | 05:03 PM
SoCalAngler's Avatar
SoCalAngler
I used vacuum hose to bridge gap. No zip ties needed as hose went on tight
Old May 11, 2014 | 05:07 PM
jfmaz's Avatar
jfmaz
Got it, thanks.
Old May 11, 2014 | 05:24 PM
rla2005's Avatar
rla2005
If there is one broken section in that white vinyl tubing then it is a matter of time before it breaks somewhere else. I like this thread from another forum: A/C and/or heater stuck on defrost - FSB Forums
It shows how to replace the entire length.
Old May 21, 2014 | 12:30 PM
Phil Woolfson's Avatar
Phil Woolfson
I use high quality silicone lines like you might see in an import. Stay away from vinyl.
Old May 21, 2014 | 01:23 PM
Ed Bamba's Avatar
Ed Bamba
Do you have link to what you have used?
Old May 21, 2014 | 01:44 PM
Lead Head's Avatar
Lead Head
I'd be surprised if rodents ate them. These lines just rot away on their own.
Old May 22, 2014 | 09:10 AM
Phil Woolfson
Sorry, I picked up mine from my stereo guy, and those were his last set a while back. I'd suggest if Summit does not have them to just Google silicone vacumme hose, and see if you can just buy a length of the piece you need, because a whole set is kind of pricy.
Old May 22, 2014 | 09:24 AM
RIKIL's Avatar
RIKIL
I have replaced all my lines and got them from siliconeintakes.com. I have not had a problem with their parts.
Old May 22, 2014 | 10:20 AM
Crewcabber's Avatar
Crewcabber
Auto zone sells the vinyl hoses in 3 foot sections. If your gonna fix it run a while new line. If you drop the glove box door you can see where it comes in and attaches to the controls.
Old May 22, 2014 | 10:52 AM
subford's Avatar
subford
Here is where the rest of the vacuum lines go:
Old May 22, 2014 | 12:01 PM
Phil Woolfson
I would not suggest using vinyl hoses for the vac lines. They can soften in the heat and get sucked in. I had, and then replaced the vinyl...
jimbo285
1978 - 1996 Big Bronco
Mar 22, 2016 05:35 PM
blaze 57
Jun 24, 2015 11:52 AM
mtbrgeek
Oct 20, 2014 12:28 PM
TexasTrash
Sep 9, 2010 10:51 PM
murph1
1997 - 2003 F150
Nov 6, 2008 10:18 AM
