Running with High ignition timing
Old May 14, 2014 | 12:30 PM
351Cleveland C4's Avatar
351Cleveland C4
Yea I've got the heads already, Aussie 302C heads.
The pistons in this motor are flat tops with 2cc valve reliefs.
Old May 14, 2014 | 03:52 PM
Tedster9's Avatar
Tedster9
It's definitely best (and a lot of fun) to experiment and try different setups. You could try 30 deg. initial and limit centrifugal to 5 or 7 or so, exactly opposite of how many have it setup. Just keep the total mechanical always to 36-38 regardless of combination or ratio; all in by 2800-3000. That should be pretty snappy too. Getting a distributor setup right can also be a pita but really pays off; and costs next to nothing. Why not get all the performance and efficiency you paid for to begin with?
Old May 14, 2014 | 10:16 PM
351Cleveland C4
Hmm. Well today was warmer outside, and I took the truck on a longer trip down the road. After the engine was fully warm, it did start to ping under moderate acceleration. So I guess 20* initial IS the edge. After I find out what milage I get on this tank I'll back the timing down to like 12 and run another tank.
Old May 14, 2014 | 11:59 PM
Tedster9's Avatar
Tedster9
Not necessarily, depends the conditions or type of pinging. Pinging at part throttle acceleration, or going up hills at speed, that's vac advance needing dialed back a little. Pinging at wide open, full throttle from a dead stop or, with heavy load; that would mean back off on initial.
Old May 15, 2014 | 12:20 AM
351Cleveland C4
Yes vacuum advance is the one that causes this particular knocking. But I've also noticed rough starting with the high initial timing.
Old May 15, 2014 | 10:31 AM
Tedster9's Avatar
Tedster9
Ah, that'll do it.
Old May 15, 2014 | 04:46 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
It's the pinging you can't audibly detect you need to worry about.
You can take apart the distributor and check which reluctor it's got. It will have slots and numbers on either side, the number is 1/2 the total mechanical advance - i.e. 13 = 26° mechanical advance. Subtract that number from your target total advance for the base timing. You shouldn't need 20° base timing unless you're running a cam with 250°+ duration at .050" lift.
Old May 15, 2014 | 04:56 PM
351Cleveland C4
I'll probably take the distributor apart tomorrow and look at it. I'll see what numbers it has and then figure out what 38* would be on initial timing.
What about vacuum advance? I tried to put an Allen wrench in the diaphragm but I didn't find an adjustment. How can I adjust that?
Old May 15, 2014 | 05:13 PM
Tedster9's Avatar
Tedster9
You can also just run it up in neutral, with a timing light, vac advance disconnected/plugged. Record the total timing in degrees at each 500 rpm increment. Should be all in by 2750-3000 or something like that, and no more than 36-38 degrees total. You have to observe this with a light at some point anyway. You can more or less deduce what slot and springs are in there that way. Unless you especially enjoy extra distributor removal/disassembly. May have to depending what you find...
THEN you're ready to add in vacuum advance if that's good in your application. Some say 3/32 Allen wrench. Couldn't find one but 2.5 mm fits the same, on mine, 30-2808 dizzy. Some say CCW to reduce advance, some say CW. Measure it to be sure. My application seems to pull in well over 10 crank degrees at full CCW testing with manifold vacuum at idle. So we can see it's working at least some. Carefully install an allen in the vac port, should be REAL gentle adjusting near the stops, sort of like mixture screws, they seem fragile and maybe easy to bugger. Have probably put 20 miles in just setting everything up, initial, mechanical, vac. Definitely worth doing.
Old May 15, 2014 | 06:38 PM
351Cleveland C4
Yea I'll do it and get it set up best I can. I would like to run 12-16* initial so I have good snap. I'll get it...
Old May 15, 2014 | 07:20 PM
BuzzLOL's Avatar
BuzzLOL
. I think only some aftermarket vacuum advances have the allen adjustment feature...
tygerrrr
Aug 29, 2009 02:01 AM
MauserRob
15
Jul 27, 2005 08:00 PM
ejfitco
Mar 17, 2005 02:05 PM
M04
Jan 1, 2005 08:20 AM
Copper93
1978 - 1996 Big Bronco
Aug 4, 2003 08:37 AM
