1978 - 1996 Big Bronco
Heat Issues
Old Dec 25, 2007 | 07:40 PM
v8xploder's Avatar
v8xploder
Heat Issues
My 87 302 bronc is being a little sob lately and not heating up. I changed the thermostat (180 degree), the coolant is nice and green hasnt been flushed in a couple years though, I back flushed the heater core and she's still acting up. shes full of coolant and i let her run for 20 min or so with the cap off to try and bleed out any air. I have not checked the heat ducts or the Blend door yet.. The temp gauge will only barely move after driving for any amount of time (but it does move) I am putting my money on the engine not completely warming up. I ran my lazer temp gauge on some things and this is what I got after driving for a half hour
Temp at vent inside 135 (degrees)
Water pump 150
upper hose 135
Those numbers seem low to me.. Any more Ideas anyone im kind of out...
Old Dec 25, 2007 | 08:09 PM
jem270's Avatar
jem270
Put in a 195 degree thermostat. It is the correct one to have.
Old Dec 25, 2007 | 08:36 PM
v8xploder's Avatar
v8xploder
Really? That sucks! I just figured 180 when I last stopped at the parts store. O well easy swap. Hopefully thats my problem Thanks for the info.
Old Dec 26, 2007 | 10:39 AM
markb210's Avatar
markb210
Heat Problems
I am having the same problem, The guy at Auto Zone recommended the heater control Valve. I can not find it in any of the books that I have. Does this even exist on a 89 ford bronco. This was after I replaced the heater core.
Old Dec 26, 2007 | 01:31 PM
helirich's Avatar
helirich
It could be that your thermistat is no good. I've had several that were bad right out of the box.
Old Dec 27, 2007 | 11:29 AM
OKLAHOMAF100's Avatar
OKLAHOMAF100
Just hook up 2k+ lbs to the tow hitch, and be done with it. My Bronco runs cold year round, but heats up nicely when pulling the boat uphill...
On a serious note...
My 95 Mustang GT ran cold year round too, but it would get hot enough to produce heat from the heater. You could always try the "big-rig fix" if all else fails, and cover half of the radiator with something.
Old Dec 27, 2007 | 06:01 PM
460srule's Avatar
460srule
Have you pressure checked your cooling system? If it is not holding pressure,it won't come to proper temperature.
Old Dec 27, 2007 | 09:06 PM
v8xploder's Avatar
v8xploder
This weekend im putting in the right thermostat, and going to buy a pressure tester for the radiator. Does anyone make a grill cover for the winter time to fit big broncs? Ive seen them on F150s i believe....
Old Dec 28, 2007 | 08:23 AM
jem270's Avatar
jem270
Your thermostat housing is probably like mine. I had trouble with it leaking. The problem was that the thermostat has to sit in a groove in the housing and mine kept slipping out. I finally had to use permatex and glue the thermostat in the housing before I installed the gasket and bolted it to the manifold.
Old Dec 28, 2007 | 04:06 PM
v8xploder's Avatar
v8xploder
good tip, i remember it being a bit of a pain to get it to stay in place too
Old Dec 28, 2007 | 05:01 PM
THE KING's Avatar
THE KING
O god lol i know all about that. What i would do if i was u is put the right thermostat in it, then pressure test it. If all else fails you have a bad heater core or a huge air pocket somewhere. When you warm it up, put the cap on and as it starts to get warm put a rag over the cap and just crack it open, some antifreeze should come out and that relives the air. Good Luck
96grimreaper
Jan 21, 2018 03:30 PM
1`badgt500
Jan 20, 2017 11:42 PM
Ron1999
1997 - 2003 F150
Jul 1, 2015 12:19 PM
Boo_Daddy
Apr 15, 2015 04:52 PM
Jimmy Dean
Dec 16, 2013 03:43 PM
