Upfitter switches question
Old 05-10-2014, 11:25 AM
jonrjen's Avatar
jonrjen
jonrjen is offline
OK, on my past trucks I had the up fitter switches and Ford was kind enough to run blunt end cut wires through the firewall and strap them to the driver side firewall for tapping into.
On my current 2013 F350 I can find the blunt end wires under the dash behind the far panel of the lower dash, but I can find none that go through the firewall into the engine compartment.
Am I over looking something under the hood, or has Ford stopped running the wires into the engine compartment?
If this is the case what is the best route for gaining access from the interior of the cab through the firewall so that I can power up some aux lights?
I appreciate your assistance, and yes I checked the owners manual which is were I learned of the blunt end wires under the dash driver side.
Thank you,
Old 05-10-2014, 12:28 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
they are there, just short as heck.. right behind the fusebox in the engine bay. taped to the harness..
also, be careful on crimping the UF wire to the passthru in the cab
I had a pair of crimpers with a cutter.. and oops, I cut the black wire for the nav GPS antenna that runs right thru this space.
note: in JonRen's post , at 35 seconds in, there is a yellow connector to the right on the wire nut, that is the GPS Antenna wire connection from the roof.. the black wire is what I cut)
didn't see it with my mirror..(can't lay upside down there)
Old 05-10-2014, 12:31 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
OK, I'll go put on my good glasses and brighter flash light and check it out again.
Old 05-10-2014, 03:46 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
Found them very well hidden. Now my problem is I lost my glasses
Old 05-10-2014, 04:25 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
I have got to find a way to get under my dash again to find the pass thru wires as well. I want to wire up the lights to my Viair and Firestone gauges.
Old 05-10-2014, 05:01 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
Here is a link to a youtube post that was of big help for me.
Old 05-10-2014, 05:06 PM
golfmedik's Avatar
golfmedik
Thanks.. Mine are so wrapped in tape under the hood that I didn't notice them at first. I take out the plastic part of the dash at the door opening after pulling down the door weather stripping so I can see better and get my XL hands in there. That helped me quite a bit.
Old 05-12-2014, 09:45 PM
Wizness's Avatar
Wizness
Wizness is offline
When I connected my lights to the wires under the hood it was easier to solder the connection by going underneath and taking out the front wheel well for what it's worth. Regardless it's a pain inside and outside the truck to make the connections.
Old 05-12-2014, 10:06 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
You would think that Ford could have added an extra inch or three to each wire simply for ease of access for the customer.
Old 05-13-2014, 03:08 PM
golfmedik's Avatar
golfmedik
Exactly my thought as I was looking at mine. No way my XL hands are getting into that small of a space to connect to those wires!!!
Old 05-13-2014, 03:44 PM
PlayersZ28's Avatar
PlayersZ28
PlayersZ28 is offline
Engineering specified 12" extra wire length, accounting weighed the wire, multiplied by the number of trucks and the price of copper and reduced the specification
Old 05-13-2014, 03:54 PM
golfmedik's Avatar
golfmedik
Damn bean counters!
F350-6
12-16-2015 07:33 PM
kevin206
11-15-2011 03:02 AM
txfour
05-20-2009 06:56 PM
357fhp
01-22-2007 08:13 PM
r3suns1994
1978 - 1996 Big Bronco
12-02-2002 11:40 AM
Quick Reply: Upfitter switches question
