Sponsored by: Real Truck
Locked axle question
Old May 12, 2014 | 08:57 PM
  #31
Tact's Avatar
Tact
Originally Posted by senix
I really don't know. you could try to put it together the opposite of what you have now. Won't hurt anything to try that.
I did. When I put the disc on the other valve the system default to blowing out of the defrost vents. I honestly think that is where it was originally, towards the front of the truck. If that's true then I believe my solenoid is bad, but I'll have to learn how to test it by the directions Tom sent. I'm just trying to verify the correct location of the plastic disc.
I really don't understand the operation of the valves in this solenoid, it may be giving enough vacuum periodically to engage the hubs, but if it is not producing enough vacuum to disengage the hubs then that may be my issue
Old May 13, 2014 | 06:21 PM
  #32
Tact's Avatar
Tact
Well, I called the Ford dealership and had him pull a new solenoid off the shelf and open the top cap. He advised once opened and the connector facing him the valve on the left(like picture above) should be the one that is covered. On mine, the valve on the right is covered, which is incorrect.
Yesterday, when I switched the disc to the valve on the left, which is the correct placement, my vents default to the defrost vents, which means I have a leak somewhere.
Back to square one.
Old May 13, 2014 | 06:31 PM
  #33
Tom's Avatar
Tom
Originally Posted by Tact
Back to square one.
That's good news, you're making progress!
Old May 13, 2014 | 06:33 PM
  #34
senix's Avatar
senix
I'd start at the hubs and work towards the solenoid checking for leaks.
Old May 13, 2014 | 06:36 PM
  #35
Tact's Avatar
Tact
Hell....it took me two days just to figure out I had the little disc on the wrong side. At this rate, the truck will be an antique when I get this issue fixed.
BTW....I really appreciate you guy's help.
Old May 30, 2014 | 03:48 PM
  #36
Tact's Avatar
Tact
A BIG thank you to whitetmw(Tom) for sending me a known good solenoid. He wouldn't even let me pay shipping. This solenoid was installed today and my 4x4 problems are solved. Auto ESOF system works perfectly, both shifting in and out of 4WD.
Thank you again Tom. Reps given!!!!!!!!!!!
Also thank you to those that gave me advice in determining that my solenoid was the issue.
ErrorS
1978 - 1996 Big Bronco
18
Dec 4, 2009 08:40 PM
Jspafford
Sep 16, 2007 10:29 PM
kimminau2
Mar 24, 2007 06:00 PM
LeeroyDiesel
Jul 25, 2006 09:32 PM
bomberboat
Jan 20, 2005 09:36 PM
