ABS Hudraulic Control Unit
Old May 9, 2014 | 08:27 PM
Immortal_Ben's Avatar
Immortal_Ben
Ok guys I need some help finding this part number, or an aftermarket part, or even a rebuild kit for it.
Ford Part #3C3Z2C386-AA
Shop diagnosed a bad ABS Hydraulic Control Unit on my Ex. Said it is a discontinued part and that one dealer in the country reported having one. Said it would cost $1400 to have him do the job and suggested I try to find an alternative solution.
Have not yet been able to call any parts yards, but will be doing so tomorrow.
RockAuto: Nothing
Ebay Motors: Nothing
Amazon: Nothing
General Google Search: NOTHING!! WHAAT?
Looks like I need some help from the mighty FTE community.
Old May 10, 2014 | 09:55 PM
je5's Avatar
je5
Are you speaking of the ABS control valve?
Old May 11, 2014 | 09:26 AM
Immortal_Ben
That may be another name for it. This is not the electronic part of the system. I need the actual valve assembly. All of the paperwork I have says Hydraulic Control Unit.
Old May 11, 2014 | 04:10 PM
je5's Avatar
je5
I would try to get a guaranteed one from a salvage yard and use a quart of fluid to flush the entire system. Did the original one go bad from old fluid?
Old May 11, 2014 | 04:52 PM
Immortal_Ben
Shop did not say why the original has gone south. I will have to see what's up from parts yards this week.
Old May 11, 2014 | 07:32 PM
Snowseeker's Avatar
Snowseeker
Bypass the unit, pull the bulb out of the cluster, and have normal brakes?
Just throwing it out there.
Old May 11, 2014 | 08:09 PM
sammie0126's Avatar
sammie0126
This thing?
Ford 4C3Z2C219AARM Genuine Factory Original Control Valve | eBay
Old May 11, 2014 | 08:55 PM
Immortal_Ben
Not something I am willing to entertain at this point, even if I knew how to do so.
Immortal_Ben
Originally Posted by sammie0126
Doubt it, that is not the same part number. But thanks for the heads up.
Old May 11, 2014 | 09:08 PM
sammie0126's Avatar
sammie0126
Ah ya I need to read closer. Your Ex a 5.4?
Old May 11, 2014 | 09:12 PM
sammie0126's Avatar
sammie0126
Ok so now I'm on a mission.... Part number is right I think the RM is added maybe for reman?
http://www.ebay.com/itm/NOS-Remanufactured-OEM-FORD-ABS-Modulator-Valve-3C3Z2C286AARM-1999-2001-7-/261399117372?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cdc99fe3c&vxp=mtr
http://www.ebay.com/itm/Remanufactured-Kelsey-Hayes-FORD-ABS-Modulator-Valve-3C3Z2C286AARM-1999-2001-/251451403615?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a8babed5f&vxp=mtr
Old May 11, 2014 | 09:48 PM
Tom's Avatar
Tom
Something like that I would suggest getting from a junk yard. You're not going to find a new factory part for much less than $1,000, and they're commonly available at junk yards. Most of the yards around here come with a 6-month warranty.
Here's what I got from a quick search on Car-Part.com
Old May 12, 2014 | 07:45 AM
Snowseeker's Avatar
Snowseeker
I understand and just wanted to give the option.
For future reference to bypass the unit you just need to pull the brake lines from the wheels out of the ABS unit and run them strait to the master. Yeah I hate ABS.
Good luck with the search!
Old May 13, 2014 | 10:46 AM
Immortal_Ben
Tom, thanks for the new resource! Never seen that site before. Found a part from a local place in those price ranges, but only a 30 day warranty.
Part ordered, will be in on Thrusday.
Christina, thank you as well for looking for me. Those parts are not quite the same part number as what I was told I need. Also, my truck info is in my sig :P
Snowseeker, I still think you are nuts for pulling without ABS, brother, haha!
By the way, I cannot rep any of you guys right now, sorry.
Old May 13, 2014 | 11:18 AM
jpr38057's Avatar
jpr38057
FYI, the part # you have posted is not the correct one. The good thing is you found one.
