ABS Hudraulic Control Unit
Old May 13, 2014 | 11:26 AM
Immortal_Ben's Avatar
Immortal_Ben
Originally Posted by jpr38057
FYI, the part # you have posted is not the correct one. The good thing is you found one.
What makes you say this? I have a printout of the test procedure the shop used, and it has the part number on it.
Old May 13, 2014 | 11:40 AM
jpr38057's Avatar
jpr38057
The part # is 3C3Z-2C286-AARM. I can look Ford parts up. They are correct in telling you the part is obsolete.
Old Aug 8, 2014 | 12:01 PM
insolution's Avatar
insolution
I don't know how this all worked out, but I can tell you from experience (at least on my 2001 4x4) that there were TWO different ABS Hydraulic Control Units (HCU) used by the factory, different part numbers and completely different plumbing layout. They are not interchangeable.
I didn't see the diagnosis listed in the post above but the symptoms of a bad HCU are (all at the same time):
1. ABS light on
2. Check Engine light on
3. Overdrive indicator on gear selector flashing
4. No cruise control
I first tried changing the speed sensor but then hunted it down to the actual ABS HCU. It's located under the driver's side battery and a real PIA to access. Mine works when it's cold out but as soon as the brake fluid warms up it quits as soon as I shut off the engine, even with a quick restart. And no, they are simply not available anywhere new or rebuilt (that I could find). Seems like a good business opportunity :-)
I have two of the wrong units to prove there are two different versions/part numbers. These were both from 2001 4x4 diesel Excursions. And both don't match mine.
I'll post the two different part numbers once I get my bad unit out. I'm lazy and have lived with it for a couple of years. The biggest issue is no overdrive, so in the end I could have probably paid for a new one just in saved fuel, had a new unit been available from Ford. If you found a new unit, consider yourself very fortunate.
As an aside, I get a lot of used Excursion parts from Custom Autos by Tim in Guthrie, OK.
Tim does stretch conversions mating a 201x F-Series to an Excursion back half, so in effect you get a brand new Excursion (or a six-door conversion which is what we ordered). Check his web site--amazing work. Looks completely factory. Beautiful body work and pretty amazing workmanship. His wiring guy is incredible.
Anyway, Tim has more wrecked Excursion chassis/bodies than any place else in the country (I'm talking acres and acres) and if he doesn't have what you need he'll know who to call.
I have no affiliation with Tim other than being a very happy customer. I flew to OKC to pick up the stretched Excursion and spent a couple of days with these guys. Terrific people. Can't say enough good things about them. Scott is the parts guy....see contact info below.
As for the ABS HCU, pull the battery and fender skirt and take a pic of the actual part number before ordering a used replacement or you risk getting the wrong one--like me :-)
Custom Autos by Tim
CABT ...The Stretch Truck Company! Upfitter
405.293.6325
Guthrie, Oklahoma U.S.A.
--Scott
Old Nov 10, 2014 | 09:52 PM
Immortal_Ben
Man, I hate when I forget to put one of my own threads to rest!
I installed the HCU I ordered and everything has been fine since.
On a side note, the only symptom my truck had was that the brake pedal would be nice and firm at first, then as it was held down (such as at a red light) it would slowly go to the floor.
Old Nov 10, 2014 | 10:05 PM
Tom's Avatar
Tom
Thanks for letting us know how it turned out!
NewEnglander
1978 - 1996 Big Bronco
Jan 29, 2019 11:44 AM
408bronco
Ford Truck Parts for Sale
Dec 30, 2010 05:29 PM
gthbryce
May 25, 2009 07:47 PM
DougNC
Mar 4, 2007 02:14 PM
95fordbronco302
Mar 6, 2002 04:29 PM
