ABS Control Unit + Pump
I'm working on changing out old brake lines to the front and rear. I removed the old lines to the front and the fittings to the ABS hydraulic control unit and when I went to reinstall one of the brass fittings to the HCU it tightened a little bit but then just started spinning, the inside threads are slightly stripped. I tried tapping it but still the same thing happened. Does anyone know if the piece circled in red and be replaced? The pump is the top piece. I'm not sure what it would be called and can't really find anything in searches.
I'll also mention that I don't even have the abs working in this truck, the sensors need to be changed which I don't plan on changing.
