MAP and EBP Torque reading
Old May 8, 2014 | 10:43 PM
Tugly's Avatar
Tugly
Originally Posted by white Buffalo
You could disconnect the MAP sensor hose and that will give you Baro Pressure.....then you could check that against your device.
That would be the same as KOEO.
Ford specific Boost can be compared with my stuff... but I think they are the same. Use "Torque Scan" on the main screen while connected to the truck in KOEO... see if BARO pops up with a value. It takes time to get all those values, so be patient and keep scrolling back and forth.
Old May 8, 2014 | 10:44 PM
Tugly's Avatar
Tugly
Originally Posted by Pikachu
In Torque, I'm pretty sure I read that BARO() is the barometric pressure reading on your device, not from the PCM.
You may be right, I didn't look into it.
Old May 11, 2014 | 05:41 PM
JWink's Avatar
JWink
I was able to swap the MAP and EBP yesterday and here are the findings.
Elevation 6600 ft, Engineering toolbox BARO table shows approx 11.5 is correct.
1st I measured his sensors in his truck.
KOEO
MAP 11.4
EBP 15.3
His are both oem and truck runs like a top.
My sensors my truck.
KOEO
MAP 11.3
EBP 14.7
His sensors my truck.
KOEO
MAP 11.4
EBP 15.0
3 bad sensors?
Torque equation in use for EBP:
((A*256)+B)*0.03625
3 bad sensors?
Thanks,
Wink
Old May 11, 2014 | 06:36 PM
Pikachu's Avatar
Pikachu
If you can get the voltage reading from the sensor, I'll see if I can track down the translations to pressure.
Old May 11, 2014 | 08:42 PM
JWink's Avatar
JWink
Thanks I will get that tomorrow and post the result.
Old May 12, 2014 | 05:09 AM
Tugly's Avatar
Tugly
I haven't seen an answer to this yet: Is the engine off? The test is no good with the engine running.
Old May 12, 2014 | 07:01 AM
white Buffalo's Avatar
white Buffalo
Yep, he posted KOEO, MAP within .2 psi of Baro. Waiting to see the numerical values to see if the formula is set right for the EBP.
Old May 12, 2014 | 07:13 AM
Dan V's Avatar
Dan V
Sidetrack alert....*We* place a lot of faith and value to the info gleaned from AE and now Torque. We know that certain versions of AE can report flawed data.
Don't know where I was going with that other than...verify, verify, verify.
Old May 12, 2014 | 08:06 AM
white Buffalo
It's a good plan, we've seen a few folks spend money on sensors because of the sensor data......then they come to find out the newer version of some of the software is all jacked up......
Old May 12, 2014 | 08:21 AM
Pikachu's Avatar
Pikachu
According to what I get from the book, the voltage reading is a linear relationship to pressure and y = 12x. So the absolute pressure should be voltage * 12, and should be fairly close to the MAP reading with KOEO. In other words, your scanner should show about 0.95 volts from the EBP sensor with an 11.4 psi MAP reading. Sensors are rarely dead on, so expect some variance from that number.
If you want to check the pins on the connector, here are the values.
With KOEO,
Pin A, grey/red tracer (signal return) - less than 5 ohms to chassis ground
Pin B, brown/white tracer (VREF) - 5.0v +/- 0.5V
Pin C, pink/light blue tracer (to PCM) - less than 5 ohms to PCM pin 30 (in case you're really feeling ambitious)
Old May 12, 2014 | 10:56 PM
JWink's Avatar
JWink
With KOEO,
Here we go, meter set on DCA 20
Pin A .03
Pin B 5.07
Pin C .92
If I follow; PIN C .92*12=11.04. Sensor is in tolerance @ +/- .46?
Thanks,
Wink
Old May 13, 2014 | 06:58 AM
Pikachu's Avatar
Pikachu
Assuming that value is with the harness connected to the sensor, key on engine off, it's very close to where I'd expect to see it. I've tried 2 different EBP sensors on my truck and the both read ~18 psi or so in Torque. When I have time, I'm going to look onto the formula and try to figure out if that's the problem. I'll also see if I can come up with a way to read the voltage in Torque.
Old May 13, 2014 | 07:27 AM
  #28
Pikachu's Avatar
Pikachu
Well, I've looked at the formula and the hex values, and the formula looks right. Why it reads a different value from what it should at a particular voltage is a mystery to me. I'd like to get this sorted out, but probably won't have time to look too deep into it this week. I'm in the middle of remodeling mom's bathroom, and have other things going on as well.
Old May 13, 2014 | 07:32 AM
  #29
Tugly's Avatar
Tugly
This suggests an issue. I wonder why so many vehicles work with the formula I posted (including mine), but the two trucks in this thread do not. I need to do some homework on this.
Old May 13, 2014 | 07:50 AM
  #30
Pikachu's Avatar
Pikachu
The formula ((A*256)+B)*((29/80)/10) is what I come up with, and is mathematically the same as the one that comes with the extended PIDs, and the one you posted. It should theoretically work fine. The formula and PID are the same for 6.0 trucks. It would be interesting to know if any 6 liter guys have experienced this.
I should say though, I haven't yet taken the time to check the voltage on the pins at the sensor. Maybe I can do that in the next couple days, and look at the readings in AE as well. I'd like to check it on a WOT run too so I can see if the difference is linear or not. If it is, I might just subtract the difference via the Torque formula and call it a day.
