Need more help
Old May 7, 2014 | 07:02 AM
Gassincowboy's Avatar
Gassincowboy
Need more help
I have a 93 150. I replaced the tires 31x10.50, Put a reman steering box,new Moog ball joints, Moog tie rod ends, Moog drag link, Moog radius arm bushings. and a front end alignment. Because it wandered and drove generally not good. After all that I feel like it wanders worse. I put about 3/4 turn into the new steering bo it helped a little) It was down right scary towing my trailer Saturday. What am I missing I'm thinking about a steering stabilizer, new front shocks and sway bar bushings next. Need some stability in this thing. Thanks
Old May 7, 2014 | 10:30 AM
andym's Avatar
andym
Shocks and sway bar bushings aren't going to help with the wandering at all. A steering stabilizer might help but you're really just slapping a band-aid on the problem instead of fixing it. These trucks steer really good when everything is new and tight so there's no reason you shouldn't be able to get it back to that point.
It sounds like you replaced most of the stuff that normally causes it to wander. Did you do the work yourself or take it to a shop?
Old May 7, 2014 | 10:33 AM
Gassincowboy
Did it myself. Everything is tight. Only thing I can think is the reman steering box is the problem. Maybe toe?
Old May 7, 2014 | 03:57 PM
wag53's Avatar
wag53
This leads me to believe you have not checked toe-in or alignment, I'd check the toe, 3/16 in at front of tires. Is there play in steering ?
Old May 7, 2014 | 04:12 PM
Gassincowboy
I had a alignment shop set the toe. Im not convinced its not at 0. I will look at the sheet tonight. I'm gonna string and check myself with toe plates also. Thanks I was searching for a toe number. I will try 3/16 . That's kind of the feeling I get now that it has been brought up. There is definitely play in the steering that's why I keep going back to the steering box seeing a have taken the play out of everything else with new parts. If I have to buy a RedHead box I will but I want to make sure that's it first. Thanks for your help.
Old May 7, 2014 | 07:37 PM
wag53's Avatar
wag53
I was incorrect on toe in chilton's says .030. That seems kind of close though, I think I set mine at 3/16
03X
Nov 26, 2015 09:14 AM
lonlyknight
Jul 1, 2013 10:48 PM
motorhead_83
19
Apr 11, 2005 01:08 AM
96ford4x4turbodiesel
Jul 20, 2004 06:08 AM
WSJ
Jan 28, 2000 09:16 AM
