So I got a Hydro booster on Ebay it said for a bronco, i got it today and the master cylinder bolt spead is wrong. i called the guy and he said to use a 69 carmaro one... Well i picked up one and the reservoir is really small. Does anyone know which one will work?
If you have a front and rear disc brakes, I am running a 77-82 corvette dual disk. It has a 1-1/8" bore with 1/2-20" front, and 9/16-18" rear brake line ports.
After looking at the Hydratech website I found they also use an S10 master cylinder which has a 1 in bore the same as the factory one. Thanks for all of the info you guys have sent me.
