Sponsored by: Real Truck
HELP 7.3 engine quit running
Old May 5, 2014 | 08:52 PM
BAMA_57's Avatar
BAMA_57
While traveling on the interstate (running at about 70) the engine began to sputter and lose power. I tried to accelerate but it keep loosing power. It finally coasted to a stop on an exit ramp. I checked the fuel filter but it looked ok. The engine would not restart. I had it towed to my home and it did restart the next day but runs rough (sounds terrible).
Old May 6, 2014 | 10:28 AM
RA31925's Avatar
RA31925
Does your scanner say you've got any codes?
Old May 6, 2014 | 12:16 PM
Kdr358's Avatar
Kdr358
Could be bad fuel, when was the last fill up? Was the truck below 1/4 tank?
Is the check engine light on? It could be bad fuel, bad CPS or a loose under valve cover harness.
Old May 7, 2014 | 08:41 PM
BAMA_57's Avatar
BAMA_57
No scanner so not sure if there are any codes.
Fresh fuel at my usual fuel stop, had about a half tank at the time.
No check engine lights on.
I put in the shop today so should know something soon.
Thanks.
Ron
Old May 8, 2014 | 09:04 AM
RA31925's Avatar
RA31925
What engine do you have?
Old May 8, 2014 | 09:13 AM
Kdr358's Avatar
Kdr358
As the title states, he has a 7.3. Hopefully the OP will post back the results.
Old May 8, 2014 | 11:36 AM
BAMA_57's Avatar
BAMA_57
It was the fuel pump!
IH Addict5088
25
Mar 27, 2017 10:26 AM
7.3guy
Mar 26, 2013 03:56 PM
Polkster
22
Dec 11, 2012 12:53 AM
Keys7.3Diesel
Nov 29, 2008 02:25 PM
crazyolbob
Nov 27, 2006 06:21 PM
