Engine Runs Rough, No Power, Now Fine?
Last night I was driving slowly around our neighborhood looking for our dog, who had run off. Truck was at normal temp from driving home from work, during which it ran great. Low fuel light had just come on, but was still well within reserve. I was idling along, window down, when the truck started shaking and clattering, would make no power, and would not accelerate. No smoke, though. I limped home at idle, the truck sounding worse all along, and it actually died in my driveway. I left it sit for a bit, while I checked fluids, which were normal. After a bit, but while still warm, the truck cranked right back up, clattered and shook again for a minute, then smoothed out and ran fine. Runs fine now. Filled up with gas and added the usual Diesel Kleen. Scheduled to take this truck on a road trip over Easter and was planning on oil and fuel filter changes prior. Wondering if anyone has ideas if this is a one-time occurrence, like bad fuel, or maybe something else? It acted like it was out of fuel, and the low fuel light was on, but it had JUST come on, and I operate in that condition every so often, so I know I had 20 miles or so (my cushion). The needle was still above E. The only thing I can come up with, is that I had replaced my batteries last weekend, and perhaps the fuel gauge was somehow affected while the batts were unplugged and not reading right? Any help or ideas would be appreciated. Sorry for the long read. Truck is 2003, 7.3 auto, 200k miles, bone stock. Thanks, Tim.
The a more than a few possibilities here Tim. One big possible culprit is the UNder Valve Cover Harness (UVCH) could be working itself loose. I have seen other posters with this problem at the beginning will have intermittent issues like you describe. Another possible cause could always be a CPS going bad. You could have picked up a partial obstruction in the tank supplying the fuel lines. In stock truck there is a sock like filter (I believe), that can become partially clogged when running low on fuel. I am sure there are others that will chime in with better guesses than I am putting forth.
Thanks for the fast replies, guys. "Cackle" is exactly the term to describe it...just a loud clattering accompanied by that loss of power. No real bucking or kicking, but the engine was shaking pretty good when I got home and popped the hood, just before it died. I have been reading about the Hutch & Harpoon mod. Makes sense to me, given the 200k + plus miles on the truck. Plan now is to run with the tank "fuller" and monitor for a bit while I plan out the mods mentioned above. Thanks again, Tim.
bulletpruf
08-12-2012 01:31 PM
allis327
02-17-2012 09:46 PM
strokerspeed
64
07-07-2011 08:53 AM
Duck Hunter81
25
01-14-2011 11:29 AM
