lower steering shaft
Old May 4, 2014 | 01:56 PM
truck157's Avatar
truck157
hi
i was trying to replace the lower steering shaft on my 98 e-250. at the u joints the bolts apparently thread into the housing and have a nut on the other side. does anyone know the size of this nut, i tried metric and sae but nothing seems to fit it. after more careful inspection it doesn't seem to be a regular nut. more like a 4 sided nut with clipped corners. of course they are in spots that are difficult to see well. i have the same situation where the shat connects to the upper u joint. would an 8 pt socket work here. thanks for the help im sure it is something simple im just missing
Old May 4, 2014 | 03:52 PM
econolinemanor's Avatar
econolinemanor
4 sided with clipped corners should be kind of a speed nut thing that may be spot welded in place. but if they start spinning around I use an open ended wrench or channel locks to hold it in place.........or
Old May 4, 2014 | 05:03 PM
truck157's Avatar
truck157
on my replacement shaft the bolt threads thru the u joint as i believe the original does also. this nut must be there as a safety measure to prevent the bolt from ever backing out. im going to pick up some replacement bolts from ford so that might make things clearer when i can see them.
GulfcoastSD
Jun 24, 2013 11:26 PM
46fordphil
1947 and Older Ford Trucks
Jun 23, 2009 12:42 PM
96_4wdr
Aerostar
Jun 7, 2008 05:40 PM
jemini
Jan 4, 2008 06:01 AM
Seifferlein
Apr 29, 2003 10:20 PM
