99 7.3 superduty won't start
1999 F250 Superduty 7.3 410k miles 2wd AT.
Yesterday while driving home from Hammond, LA. The truck was running great and while traveling home I eased up on the pedal for a 35mph area and the truck just quit. I coasted to a safe area and attempted to restart with no success.
I checked the oil, witch I had changed 24 miles previously. It's full.
I removed the fuel filter cap. It was full. I drained it and turned the key on. It refilled at a good rate. I replaced the cap and tried to restart. Apparently I caught some debris which caused a tiny high pressure squirt of fuel from under the cap. I removed the cap and cleaned it. After replacing the cap I tried to restart. No leaks and no start.
I ran to the dealer and purchased a new cam sensor came back and installed it. Still no start.
I towed it home, charged both batteries, let it sit overnight.
Still no start.
I replaced the IPC with a used one about 50 miles ago. I checked it and no oil on the plug.
CEL comes on
Tach showed RPM while cranking
No smoke
I could use some help please. Keep in mind I'm not familiar with all the abbreviations and have no access to a code machine.
Thank you in advance
Still no start.
CEL comes on
No smoke
Just sitting here staring at my truck. Won't be able to find a mechanic till tomorrow. And probably have to spend some big bucks. So what can I do now, myself.
As having the oil and filter changes only 24 miles ago could this have anything to do with my problem? They told me they put in Rotlla.
harold1814
07-18-2016 10:08 PM
Captain George
48
05-08-2014 06:45 AM
G man 12
02-15-2011 10:57 PM
