87 6.9idi trans issues
Old May 3, 2014 | 06:17 PM
buzzy613's Avatar
buzzy613
Today I looked at an 87 f250 with the 6.9 idi and I believe c6 trans.(only guessing since I was told a 3 speed) but I was told that if you start it up it won't move right away if you put it in drive but what's its moving it shifts like a dream but if you park it and wait about 20 mins it will do it again. What would cause this. I know if I knew what trans was in it it would be a whole lot more helpful but I do not have much knowledge on these diesels
Old May 3, 2014 | 06:45 PM
buzzy613's Avatar
buzzy613
Could it be the torque converter also?
Old May 3, 2014 | 08:40 PM
airdale94's Avatar
airdale94
Did you check the fluid level?
Old May 3, 2014 | 09:08 PM
buzzy613's Avatar
buzzy613
It was full and didn't smell burnt at all
Old May 4, 2014 | 07:31 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could be a bad first gear clutch pack, or a bad seal in the front pump.
either way the trans is going to come out and get refreshed.
and depending on how many miles are on it, it may need a new planetary housing also.
the last one i had done cost $600 to replace the planetary housing, all the clutch packs, pumps, and torque converter.
Old May 9, 2014 | 06:52 AM
1bigjoe's Avatar
1bigjoe
replace the vacume accuator on the outside of the trans
Old May 9, 2014 | 07:49 AM
buzzy613's Avatar
buzzy613
1bigjoe that's what I'm thinking just to rule it out
Old May 9, 2014 | 04:13 PM
SEH43's Avatar
SEH43
Buzzy- if you do have a C6, drop it down one gear to position #2, this will then start off in second gear. This, I think, should bypass the first gear clutches. If no change, you are loosing hyd pressure, and it will need to come out.
Old May 9, 2014 | 07:09 PM
Johnny L's Avatar
Johnny L
the EXACT same thing happened to mine. worked perfectly except that it took like 60 seconds of revving to get it to move in drive (reverse worked fine instantly). i never did figure it out. i assumed it had to do with the trans fluid warming up. sold the trans as-is for $50 and did my ZF5 swap.
Old May 9, 2014 | 10:44 PM
buzzy613's Avatar
buzzy613
Well we took it for a drive to day. A lot or white blue smoke smelt like oil when we first took off but it does sit a lot and it took off fine slipped a lot when we first took off the shifted OK and a little hard and better from 2nd to 3rd. The more we drove it the better it felt really firm shifts too but a little slip right before engagement. So this could be the cause of more things?
stroked 347
Jul 31, 2008 11:39 AM
Saigon
Sep 16, 2006 07:01 AM
blueknight44
May 30, 2006 09:33 AM
ford390gashog
Apr 10, 2004 09:00 PM
ultrabeast
Sep 23, 2003 08:47 PM
