Got some numbers, what next?
Old May 3, 2014 | 05:50 PM
catalinaflyer's Avatar
catalinaflyer
So I'm finally back in Kansas with the wife's new to her 04 F250. She picked me up at the airport in it and it was running just as rough as before along with no power.
I had ordered the SCII but it never made an appearance (different story for another day) so I downloaded the paid version of Torque and hooked it up, here's what I got just sitting in front of the house just now,
Idle:
ECT 177.8
EOT 174.6
FICM 48.0
Chassis volts 13.5
HPOP 649.2
And I guess I didn't capture at 2500 rpm but the HPOP was up around 1700 I believe.
What numbers and readings do I need to get in order to help with a diagnosis?
Old May 3, 2014 | 06:24 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Need ECT @ 185+ for accurate numbers...
ICP looks good @ 640
Need:
IPR%
VGT% Idle
EBP
MAP
Baro
Engine Load Cold idle versus Hot idle is good to know
Josh
Old May 3, 2014 | 07:30 PM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Did you say you are in Kansas???
Old May 3, 2014 | 07:35 PM
Bullitt390's Avatar
Bullitt390
Thread-Hijack: I'm originally from Hutchinson...
Josh
Old May 3, 2014 | 07:39 PM
diesel_dan's Avatar
diesel_dan
and I don't think there was a mention of Toto, either...
Could be time to BP the new (to your wife and your) '04
I can tell you where I'd take it to....
Old May 3, 2014 | 07:43 PM
diesel_dan's Avatar
diesel_dan
dang it and holy Toledo! Sorry, Ohio is a whole other state (of) mind...
Old May 3, 2014 | 08:07 PM
catalinaflyer
Yes, I'm in Newton for the next week then loading everything we own into boxes, putting them in a truck and moving to Toledo, OH. My wife will be towing her 30' pontoon boat up there with it so hoping I can get it running well enough for a 900 mile trip.
Old May 3, 2014 | 08:13 PM
04badford's Avatar
04badford
What's it doing and is there any codes, remember the wrench light does not have to come on to have stored codes, How close are you to Anthony
Old May 3, 2014 | 08:29 PM
Bullitt390's Avatar
Bullitt390
Wrench Light on an 04?
Josh
Old May 3, 2014 | 08:50 PM
04badford's Avatar
04badford
wrench or wench lol ,sorry Light don't have to come on to store codes
Old May 3, 2014 | 08:51 PM
04badford's Avatar
04badford
our's is a pic of an engine that's our wrench .
Old May 3, 2014 | 09:03 PM
catalinaflyer
It's running very rough, almost no acceleration and the codes stored:
P0046, P0281-cylinder 7 contribution/balance, P0603-KAM Error and U0306.
I'm going to change the oil (Rotella T6 and motorcraft filter) and put the blue spring kit in it tomorrow morning.
Old May 3, 2014 | 09:10 PM
04badford's Avatar
04badford
Yes # 7 Injector , 0046 is VGT , take a look at the connection maybe rusted up or loose/chaff wire
Old May 3, 2014 | 09:16 PM
04badford's Avatar
04badford
I have no lower u codes, these are added , did you hook something up via PCM or fuse box?
Old May 4, 2014 | 06:48 AM
catalinaflyer
I have looked at the connector after I looked that code up on here (one of your responses to another member). Can't see a problem with the connector so will dig further into the wiring. As for the injector, how do I test to see in its the injector itself, wiring or FICM? Back the day after she got the truck we were sitting out in front of the house waiting on my son in law to get here with it idling when it all of the sudden went smooth and ran perfect for a 100 mile trip but was right back like it is now after sitting all night. (Number 7 is the most rearward on the drivers side like a SBC right?)
I have not added anything but there was an aftermarket alarm system when she brought it home. I removed everything from it and reconnected the wiring in the drivers door where they had added a relay for the electric locks. The installation looked semi-professional (like a Best Buy, about half way between a home done hack job and professional audio shop job)
