Random Bogging and check engine light
Old May 2, 2014 | 11:44 AM
Aagerrie195's Avatar
Aagerrie195
I have a 1992 f150 with a 4.9L Straight 6. My truck has a mind of its own, sometimes it will start right up with no problem and then other times i can't get it started to save my life. But when ever i do get it started i will take it for a quick cruze and out of no where a check engine light will come on and i will like all power and it just bogs in every gear. its still sorta driveable but barely. So i have checked all my sensors and they all seem good. so i came to the conclution that its either a bad fuel pump but i thought that would make it run like **** all the time, random misfiring, or maybe a wiring problem. The motor only has 80k on it so i guess im just confuesed im not that mechanically savvy so i guess i just wanna see if anyone has a similar problem or to see if im on the right track. I tried checking for codes but it came up that there where no codes saved. Id appreciate any help I can get.
Old May 2, 2014 | 04:59 PM
mpriester's Avatar
mpriester
the check engine light comes on and there are no codes. you may want to double check that.
Old May 2, 2014 | 07:00 PM
andym's Avatar
andym
I'd like to know how you're pulling codes.
gt5-33
Jun 1, 2005 07:39 PM
j94tbird
Jan 8, 2005 09:38 AM
WildTurkeycj8
Modular V8 (4.6L, 5.4L)
Apr 18, 2004 04:26 AM
rwsam
1978 - 1996 Big Bronco
Jun 9, 2002 07:22 PM
