Sponsored by: Real Truck
02 7.3 running rough need help
Old May 1, 2014 | 11:05 PM
txwavman's Avatar
txwavman
This is my symptoms:
On cold start ups engine runs rough. Idling it knoicks worse than niormal on the road she runs really rough. If I get on here she smooths out ( but still runs rough a bit) but normal driving at between 1200 -2000 rpm she runs so rough it shakes the whole truck. It will do this until she gets up to operating temp & then it goes away. The more she warms up the better she runs. Once up to temp she will run perfectly. The colder it is outside the worse it is & the longer it takes for it to go away. I have replaced the valve cover gaskers and new harnesses, new glow plugs. Still same problems. I have AE and one time it gave me a #2 cylinder code. have not been able to repete this code. Any suggestions on how to fix this problem or any suggestions on what to check next.
Old May 2, 2014 | 11:33 PM
Jnowaczyk's Avatar
Jnowaczyk
have the codes read could be clogged injectors a bad sensor ect have the codes red and it will give you a idea whats wrong
Old May 3, 2014 | 09:11 AM
txwavman's Avatar
txwavman
i have AE i keep it on all the time, and i have been treating it bad to try to make it code but it will not code. I have run all the test that i can think of. The only code that i have ever been able to get off it was a #2 cylinder code one time right after start up. i have not been able to get that code again.
Old May 3, 2014 | 10:20 AM
Jnowaczyk's Avatar
Jnowaczyk
watch some videos may help you find something POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners & Mechanics
Old Jun 17, 2014 | 07:48 AM
Tycose's Avatar
Tycose
Reading other posts and having the same problem as you, the common thread is a worn injector #8 but can be the same for any injector. I believe the gap is suppose to be .015", but do read up on this as I am just a parrot repeating other peoples threads.
Old Jun 17, 2014 | 11:47 AM
thomabb's Avatar
thomabb
What oil are you running, and how many miles are on it?
Brookloving
Feb 16, 2019 12:29 PM
M fire
Mar 13, 2014 11:23 PM
dbrunner94
Jul 26, 2013 06:17 PM
bwalshma
Mar 29, 2005 01:02 PM
