Hyduralic Lash adjusters Question
Old 04-27-2014, 10:04 PM
Ford'05HG's Avatar
Ford'05HG
Ford'05HG is offline
Howdy Guys! I have a 2005 Ex with the 5.4 3v. Just 2 months ago I rebuilt all the timing like phasers, chains, solenoids, and the phasers cause they were really starting to annoy me. Couldn't hear over the engine at the drive thru.
I did the oil pump an all exterior gaskets. But while I was in there I noticed a rocker had seized and got kicked during a time I was pulling 4000 rpms. So I didn't exactly know how to change the rocker out then so I just left it without one since it was and intake valve and it still had another one.
A week or two ago I read these motors use hydraulic lash adjusters and it got me thinking, because I didn't remove the adjuster just the rocker, that maybe I should've put one in there because the oil might be losing pressure due to this open adjuster. What do you guys think?
Old 04-29-2014, 01:29 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It's probably not a major issue, but I would reinstall the rocker. You should be able to loosen the cam bolts a bit to reinstall it.
Old 04-29-2014, 02:26 PM
Ford'05HG's Avatar
Ford'05HG
I decide not to to do it also in part to the fact that it filed the cam lobe down to the point where its probably useless in that spot. So I just figure there was no point in putting one in.
Old 05-01-2014, 10:52 PM
je5's Avatar
je5
je5 is offline
Did the metal come out in the filter?
Old 05-02-2014, 01:23 AM
Ford'05HG's Avatar
Ford'05HG
I actually don't do the oil changes myself so I cant say if it did it not.
Ford'05HG
1997-2006 Expedition & Navigator
04-26-2014 11:15 PM
mabigredtruck
02-16-2010 11:05 AM
black58
06-04-2006 09:21 PM
Crowbar65
04-03-2003 07:54 PM
Quick Reply: Hyduralic Lash adjusters Question
