Sponsored by: Real Truck
how to remove front body mount
Old May 1, 2014 | 03:47 PM
bubbasz1's Avatar
bubbasz1
i have a 2008 f250 4x4 i need to replace the drive side front lower body bushing and i can not get the pressed on bushing to come out what is the easiest way to get this to come apart i tried using a 4 ft pry bar and i could not get it to pop free any ideas
Old May 3, 2014 | 12:54 PM
CPB1's Avatar
CPB1
Well, I have searched high and low for body mount replacement on here. Most of the talk is on the Excursion forum.
What some are recommending is to thread the bolt back in about a half inch or so then beat on the bolt head to pop the bottom part loose.
Post back and let us know how you make out as this is my next project.
Old May 4, 2014 | 06:19 AM
huegeljr's Avatar
huegeljr
Here is how Energy Suspension recommends the removal.
They tell you to make a tool out of pipe. I have new bushings on order and will have to make one within the next few weeks. http://www.energysuspensionparts.com...n/17P17627.pdf
Old May 4, 2014 | 08:02 AM
CPB1's Avatar
CPB1
So you ordered the Energy Suspension polyurethane body mounts? I am very interested in how they ride. I will be doing this in the next week or two, but am unsure what type to get. The Ford OEM or the polyurethane.
Thanks for the tip.
Old May 4, 2014 | 08:17 AM
huegeljr's Avatar
huegeljr
I wondered the same but figured they to be better than the deteriated ones that are currently on it banging around.
For what I see I couldn't afford the OEM.
Sent from my XT1080 using IB AutoGroup
Old May 4, 2014 | 09:31 AM
CPB1's Avatar
CPB1
Good point, I have read pros and cons about the polyurethane. One says "rides fine" other says to "much vibration".
My mounts are also causing handling issues, or at least that's what I am thinking. They also bang around and feel spongy under my feet. So at this point anything is better then the worn out crap that's on there now.
Good luck, and let us know how you make out. Not much info on here about body mounts.
Old May 4, 2014 | 10:30 AM
bubbasz1's Avatar
bubbasz1
Well, We just had to replace one lower body mount, front drovers side. Ended up using a big pry bar with a pipe on the end of it and it came off. It was a pita but it lost, new one went on easy as pie.
Good luck with your projects.
Old May 5, 2014 | 02:35 PM
huegeljr's Avatar
huegeljr
Well received my new body bushings today. Energy suspensions is the manufacturer. First impressions, they are not as hard or ridged as I expected. They are rather soft which is good. Hopefully I can get them on at the end of the week.
Old May 5, 2014 | 02:48 PM
xmontex4's Avatar
xmontex4
Take pics of the process please, I want to lift the cab slightly so i can get under there with some POR15 so i might as well replace them while I'm at it.
Old Dec 28, 2016 | 09:06 PM
Brbeckett's Avatar
Brbeckett
I know this an old thread but could some one please tell me how many body mounts are on a 2008 F250 XLT Supercab. I can only see 4 and wondering where the other two are because all replacement kit include 6 bushings.
Old Dec 29, 2016 | 12:23 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Four for the cab and then two under the radiator support
Old Jan 3, 2017 | 04:55 PM
speakerfritz's Avatar
speakerfritz
if its already spining...get someone with a wire feed flux welder and have them tac weld the nut to the frame.
if you are just starting the project....heat the plate up with a toruch
do not use an impact....get a large breaker bar and large ratcher
mwacosta$
Feb 26, 2021 06:34 AM
ChrisMelton78
Sep 28, 2014 01:07 AM
dieseldodgeguy
Jul 28, 2013 10:37 AM
Jarryd
Jun 25, 2013 04:47 PM
SgtRock
Bronco II
Feb 8, 2005 04:07 PM
