Wheel spacers
Old May 1, 2014 | 02:29 PM
Phantomfueler's Avatar
Phantomfueler
Wheel spacers
I have a 2013 f-150. , with a 4 inch lift . Looking at getting wheels spacers . Any ideas on a good spot to get them and what will fit ?
Old May 2, 2014 | 11:59 AM
gDMJoe's Avatar
gDMJoe
Phantomfueler - Any ideas on a good spot to get them and what will fit ?
  1. WheelAdapter.com
    • VERY HIGH quality. *A real concern if you plan on any off-roading.
    • you'll pay for the quality. e.g. $$$$$
  2. MUST be hub centric. *FoMoCo centers the wheel(s) via the hub not the lugs.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old May 2, 2014 | 05:34 PM
GTXgp's Avatar
GTXgp
Make sure to measure for exactly what size spacer you want and how much thread you have available. If it is a really wide spacer, you can get the lug to fit "inside" the spacer... if it is a narrow spacer, you may have to trim the OE studs! I've always been a bit nervous about this one!
Old May 2, 2014 | 09:46 PM
gDMJoe's Avatar
gDMJoe
GTXgp - Make sure to measure for exactly what size spacer you want and how much thread you have available. If it is a really wide spacer, you can get the lug to fit "inside" the spacer... if it is a narrow spacer, you may have to trim the OE studs!
The minimum thickness for a wheel adapter is 1¼". Anthing less than that and the rims' mounting flange will not make contact with the hub since the stud is 1½" long. Exception: If the rims' mounting flange has recesses between the bolt holes you could use 1", HOWEVER, you would need to trim-off the ½" unthreaded nipple of each stud. *Would NOT recommend doing this).
The maximum thickness for a wheel spacer is ¼". Any more than that and there will not be enough stud thread to safely secure the wheels.
Old May 2, 2014 | 11:51 PM
CuNmUdF250's Avatar
CuNmUdF250
I wouldn't.
Old May 3, 2014 | 06:05 PM
fishbones182's Avatar
fishbones182
Originally Posted by gDMJoe
  1. WheelAdapter.com
-click- the pic'
Goth 150
+++1 those are great spacers that will hold up. Just be sure to keep an eye on the torque of the nuts on the spacers.
cmorningstar01
2009 - 2014 F150
Aug 5, 2019 11:45 AM
CamoF-250
May 4, 2019 11:48 AM
ufvj217
Jun 8, 2017 09:34 PM
Hans77
Aug 16, 2007 06:19 PM
Double A Ron
1997 - 2003 F150
Aug 10, 2005 09:00 PM
