Needs ALT upgrade
Old May 2, 2014 | 06:37 PM
maverick600's Avatar
maverick600
Originally Posted by JEFFFAFA
I don't see how the gauge or light in the dash would work with a "1 wire". I certainly wouldn't want to run that one wire totally through a factory gauge.
I thought you had helped me out when I did mine....you can work the gm alt with 1 wire but....you have to rev the engine up after cranking to around 1200 rpm to get it to start charging. Thats how mine was set up and my alt light stayed on all the time. I have (3) wires hooked to mine....1 wire is from the wiring that went to the stock voltage reg, the other 2 wires go to the hot side of the solenoid. If interested I can take pictures of mine and send you the link.
Old May 2, 2014 | 11:31 PM
nkf's Avatar
nkf
Originally Posted by MIKES 68 F100
did the 3g , I recommend the Painless install kit , made everything easy and very clean .
With the battery isolator in line, the kit may be a waste of money on my end. I did pull the wiring from the alt over to the battery.
Old May 3, 2014 | 02:40 PM
f100today's Avatar
f100today
3G is an awesome upgrade for these trucks. Not sure why u would need to buy a wiring kit from anyone? It is very simple. If you want NEW stuff it is all available on ebay as well. DBelectrical has new alternators at good prices.
Old May 3, 2014 | 06:04 PM
nkf's Avatar
nkf
Picked up a Max fuse setup and extra belt pulley. Now I need the battery isolator* and then time for the install
Anthonyawh
2004 - 2008 F150
Jun 23, 2019 10:44 AM
caedo
Oct 21, 2017 07:16 PM
facotaco
Nov 18, 2011 01:09 PM
rdct
Electrical Systems/Wiring
Mar 19, 2010 07:56 AM
torro4000
Aerostar
Jan 4, 2006 09:14 AM
