351M intake install tips
Old Apr 30, 2014 | 01:55 PM
1979 300i6's Avatar
1979 300i6
Just got a aluminum intake for my 351 and was wondering if I need to buy a new Valley pan gasket or are they reusable? Also should I just use silicone for the ends or use the rubber gaskets? Any other tips are appreciated thanks
Old Apr 30, 2014 | 05:01 PM
HIO Silver's Avatar
HIO Silver
Dunno about 351M valley pans
But I'd just use RTV on the ends... ya might wannaa dimple the end rails so the RTV have some "feet" to grab onto unlike a straight smooth surface.
When applying the RTV, it's not a straight bead.. rather it's daub-lift-daub-lift.... try to make it look like a string of nice TIG welds. Wait for about 10 minutes for it to skin over and then place the manifold straight down. It doesn't hurt to pre-fit the intake to determine how tall the RTV has to be.
Have fun!
Old Apr 30, 2014 | 05:03 PM
hivoltj's Avatar
hivoltj
Ditch the leak-prone valley pan. They usually don't seal well with aftermarket intakes.
Use the paper gaskets from Mr. Gasket or Fel-pro and silicone on the end rails, make sure to overlap the gasket a little and use the torque sequence!
The inner bolts will loosen as you tighten others so keep repeating the pattern until they all stay snug.
Old Apr 30, 2014 | 06:51 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X3 on the silicone or RTV, the rubber seals will work there way out.
Old Apr 30, 2014 | 07:07 PM
1979 300i6's Avatar
1979 300i6
Would heat resistant red RTV be good to use?
Old Apr 30, 2014 | 07:11 PM
77&79F250's Avatar
77&79F250
Permatex Ultra Copper Max temp IMO...
Permatex Ultra Copper Maximum Temperature RTV Silicone Gasket Maker (3 oz) - Permatex 81878 | FCP Euro
Old Apr 30, 2014 | 07:13 PM
1979 300i6's Avatar
1979 300i6
Alrighty then sounds good
Old Apr 30, 2014 | 07:45 PM
HIO Silver's Avatar
HIO Silver
Below is an example of dimpled China walls. A broad punch and hammer gets the job done. You can also go the extra mile and dimple the underside of the intake too.
Old Apr 30, 2014 | 07:50 PM
1979 300i6's Avatar
1979 300i6
thanks for the picture I will make sure to do this
Old May 1, 2014 | 11:31 AM
1979 300i6's Avatar
1979 300i6
I decided to go with the valley pan, do I lay I layer of silicone on top of the valley pan where the intake meets or just on the block?
Old May 1, 2014 | 01:57 PM
Filthy Beast's Avatar
Filthy Beast
Those cake pans should not be re-used if you want a good seal.
Pre- bend the pan a bit and test fit on the block and check how the intake fits. Hopefully, you still have those little nubbies on each head - they help hold the pan in place while fitting the intake if you don't bend it.
Silicon/RTV the china walls and up the sides a bit first....while that's "breathing" or tacking over, RTV both sides of the pan, around every opening with a light layer. A thicker layer should go on the pan's top "S" ends and up the sides a bit.
Install intake and torque to specs/sequence.
Old May 1, 2014 | 02:57 PM
1979 300i6's Avatar
1979 300i6
Originally Posted by Filthy Beast
Those cake pans should not be re-used if you want a good seal. Pre- bend the pan a bit and test fit on the block and check how the intake fits. Hopefully, you still have those little nubbies on each head - they help hold the pan in place while fitting the intake if you don't bend it. Silicon/RTV the china walls and up the sides a bit first....while that's "breathing" or tacking over, RTV both sides of the pan, around every opening with a light layer. A thicker layer should go on the pan's top "S" ends and up the sides a bit. Install intake and torque to specs/sequence.
thanks a lot, and yes I put a new one on
schmorbraten
May 9, 2018 09:18 AM
GruesomeJeans
Feb 26, 2014 02:19 PM
virgojeep
Nov 15, 2009 02:54 PM
sams78
Nov 8, 2005 03:27 PM
marcveinotte
Dec 6, 2004 09:22 AM
