RABS VALVE?
Old Mar 7, 2012 | 08:51 PM
Shanemh's Avatar
Shanemh
RABS VALVE?
TRYING TO FIGURE OUT WHERE THE RABS VALVE IS LOCATED AND WHAT IT LOOKS LIKES. DID A FRONT BRAKE JOB, BLED THE BRAKES BUT STILL GETTING NO PRESSURE. SOMEONE SAID TO BLEED THE RABS VALVE TOO. WHERE IS IT?
Old Mar 7, 2012 | 08:58 PM
White 97 xlt's Avatar
White 97 xlt
It's on the inside of the frame, right under your feet when you are sitting in the drivers seat.
It's a cast iron chunk of metal with a brake line at the front , a brake line at the back and a wire harness plugging into about the middle..
Old Mar 7, 2012 | 09:41 PM
rla2005's Avatar
rla2005
Unless you let the master cylinder go dry during the brake job and bleeding process the RABS and rear brakes will not be affected. There is zero connection between two except the reservoir of the master cylinder.
What kind of "brake job" did you do? Replace calipers? If so did you re-install them with the bleeder screw on the top side?
A photo of a RABS module
Old Mar 7, 2012 | 10:08 PM
Shanemh's Avatar
Shanemh
I replaced pads, rotors, bearings, seals, master cylinder.
Old Mar 7, 2012 | 10:24 PM
whiteboyslo's Avatar
whiteboyslo
If you don't immediately see it, follow the rear brake lines forward. Can't miss it.
Mike
Old Mar 8, 2012 | 08:30 AM
rla2005's Avatar
rla2005
That one item right there is going to be the trigger point. Yes, you will need to bleed the RABS as well as the rear brake cylinders. It's not too bad. I just went through this ordeal about 2 months ago. My RABS was covered in rust, amazingly the bleeder screw popped loose rather easily.
I did cheat a little......I have been periodically spraying the bleeder screw with PB Blaster for about a year. I knew one day I was going to have to crack that baby open
Old Mar 8, 2012 | 09:22 AM
whiteboyslo
Yup. That's the trick right there.
Mike
Old Feb 28, 2016 | 11:56 AM
4sooth's Avatar
4sooth
I just replaced the RABS on my 1993 F-150 XLT--cured a long time issue with the brakes locking up, flashing codes, and other issues. A friend and I got three out of a wrecking yard--installed the best looking one--problem solved and we have two spares. Cost--$9.00--yep-the guy lots us have all three for that one price. It was well worth the two hours of hunting around and crawling under trucks!!
Old Feb 28, 2016 | 12:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
did you bench bleed the master cylinder before putting it on? if not, you will never get the system properly bled or get a solid pedal.
Old Feb 28, 2016 | 01:36 PM
bashby's Avatar
bashby
Old thread Tom.
Old Feb 28, 2016 | 02:59 PM
tjc transport
i ain't rite
aw crap!!! suckered into responding by a new guy.
and i usually check dates before posting too!
Mother_Love
1978 - 1996 Big Bronco
Jan 11, 2012 07:11 PM
gopher2
May 25, 2010 07:36 AM
2blue
Jul 21, 2009 12:34 PM
kvanderstel
1983 - 2012 Ranger & B-Series
Mar 21, 2004 11:29 AM
sternal2000
Feb 11, 2004 11:03 PM
