EGR operation/test
Old Apr 30, 2014 | 07:04 AM
1 Ton Tommy's Avatar
1 Ton Tommy
EGR operation/test
I pulled my egr, as the service engine soon light came on. It was relatively clean, with only a little dry, black soot visible. I hooked it back up and cycled the ignition switch with the valve body sitting on top of the block. I observed no change in the position of the switch. I was thinking it should open and close from what I read in the threat on disconnecting the egr. The truck was cold and unstarted for 24 hours. 06 model. Should it open and close with the ignition key cycle? Thanks!
Old Apr 30, 2014 | 08:30 AM
jswartz84's Avatar
jswartz84
No.
While watching the commanded and actual values on my SG2, my EGR valve won't move until I'm up to operating temp. After that, it looks like it moves in relation to throttle position.
Old Apr 30, 2014 | 08:57 AM
1 Ton Tommy
Thanks! Just did chores with it, and I will pull the valve while warm to see if I can make it operate. Appreciate the reply.
Old Apr 30, 2014 | 09:21 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Get the codes read. They stay in memory even if the light goes off (unless you pull the batteries). That will get you on the right track.
Fal-308-Win
Feb 21, 2014 06:21 PM
Fulthrotl
May 5, 2013 01:15 AM
ravens fan
Mar 21, 2013 08:26 AM
Fluid Power
May 30, 2007 12:32 AM
jeepin
Aug 26, 2003 11:26 PM
