Headliner install
Old Mar 15, 2015 | 12:16 PM
  #31
mhstigers96's Avatar
mhstigers96
I just bought one of theirs. Did you use the old clips or put in screws? I have nothing there.
Old Aug 24, 2021 | 02:51 PM
  #32
Watto's Avatar
Watto
Headliner
Originally Posted by gangstakr
Made my own. Made it to resemble the hood.
Hy Gangstakr, Reading about headliners and saw you mentioned you made it like your hood. That sounds pretty cool, you have a photo of that?
Watto
Old Aug 24, 2021 | 09:33 PM
  #33
1965GTFB's Avatar
1965GTFB
Originally Posted by Shadowrider123
Check these guys out.
65-66 Ford Full Size Truck, Standard Cab Headliner, F100/F150 1965, 1966
I bought one of their headliners and it is top notch.
WARNING!
I tried one of those, with the vinyl attached.
The glue they use is junk, it all started coming loose in a matter of days.
The basking/ABS is too stiff it was a pain.
Called them and they gave me my money back.
Not the stock look but I went with Rod Doors.
https://www.ford-trucks.com/forums/1...ight=headliner
Old Aug 25, 2021 | 07:04 AM
  #34
jjriley97's Avatar
jjriley97
Mine is made from FRP and I'm doing vinyl. This is the only adhesive to use. Anything else is a crap shoot.
It is heat resistant and will not let go. I grabbed some of the 3m super 90 initially because it was close and it held for about 3 months. I used almost 4 cans on the headliner($48) a couple times trying to fix it, but it just doesn't hold up to the Oklahoma heat so I am back to what I know works. I get it locally for $42/gallon. It can be sprayed or brushed.
This was after using the 3M that failed. The redone headliner will be done by this weekend and will look a little different.
Old Aug 25, 2021 | 01:54 PM
  #35
gangstakr's Avatar
gangstakr
Watto
Here you go.
Old Aug 25, 2021 | 03:14 PM
  #36
jjriley97's Avatar
jjriley97
Very cool truck.
Old Aug 25, 2021 | 06:29 PM
  #37
66F250_4x4's Avatar
66F250_4x4
Thanks for this tip. I'll be getting a can.
I've had the same results: The ABS headliner from ACME and supplied by multiple vendors is a nightmare to install, and the vinyl has delaminated after a couple of months. I also requested a refund.
I'll be getting the Roddoors and covering it with vinyl - with the hope that this DAP will hold it there.
Old Aug 26, 2021 | 07:30 AM
  #38
jjriley97's Avatar
jjriley97
No problem. You won't regret it. A good brushed on coat on each piece that is dry to the touch will not let go once pressed together. You can reposition it if it hasn't been pressed together, but after pressing it's bonded.
Old Jan 18, 2026 | 10:25 PM
  #39
Paul Webster's Avatar
Paul Webster
Trailering
Originally Posted by tbm3fan
Headliner as done by the factory with the original clips no less and screws.
Thanks for sharing ideas, tbm3fan and others.
Anyone got a pic of the front clips installed on the big center piece. I have the clips, but want to understand distribution and orientation of those front clips. I have built panels traced from my original, but with frp, covered w/ vinyl.
Mine is a 66 f-100.
Old Feb 9, 2026 | 03:22 PM
  #40
doug64f100's Avatar
doug64f100
What is your headliner made out of? That is awesome!
Doug
Old Feb 9, 2026 | 04:31 PM
  #41
1965GTFB's Avatar
1965GTFB
Doug
Which one of the headliners mentioned are you referring to?
Old Feb 9, 2026 | 04:53 PM
  #42
doug64f100's Avatar
doug64f100
I was talking about Gangstakr's headliner. That is really cool and I bet it really quiets the cab noise!
Doug
Old Feb 9, 2026 | 05:29 PM
  #43
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Doug
Robert, gangstakr, hasn’t logged in since 2023.
Old Feb 9, 2026 | 07:18 PM
  #44
doug64f100's Avatar
doug64f100
Bummer.
co425
Sep 10, 2011 05:59 PM
jaye
Oct 28, 2009 11:50 PM
428cobrajet
Apr 24, 2007 10:47 AM
