Headliner install
Old Sep 9, 2014 | 11:58 PM
Shadowrider123's Avatar
Shadowrider123
I have the same headliner jm, I have not installed it yet.
I put insulation on the cab roof and on a hot day I still cant keep my hand on it.
My plan is to buy a roll of fiberglass insulation made for walls and put a 1in layer between the headliner and the roof.
In addition to keeping some heat out, it should also dampen some noise, I hope.
Old Sep 10, 2014 | 02:17 AM
jmstenseth's Avatar
jmstenseth
Drop top headliner
I did insulate with a foil bubble type heat sound barrier. Used it on my floors and inside my doors also. JMS
Old Sep 10, 2014 | 10:08 AM
salf100's Avatar
salf100
Originally Posted by scottlathrop
shoo - do you mean supplier of headliners or pdf to make your own? I made my own thru a pdf but may not "fit " as a resto like the astronaut is doing.
Yours looks great! What did you use? I was at Home Depot yesterday and saw this white ABS (I think) 4'x8' sheet for $15 and thought about trying that for making a head liner. It was a little thin but figure Y not?!
Old Sep 10, 2014 | 10:42 AM
Shadowrider123
Scott, on your back piece did you drill into the lip for the screws, or did you put a backing plate in there?
Old Sep 10, 2014 | 06:35 PM
1964FORDTUF's Avatar
1964FORDTUF
Originally Posted by tbm3fan
Headliner as done by the factory with the original clips no less and screws.
That is sweet...Fac-to-ry...!
Old Sep 13, 2014 | 01:18 PM
scottlathrop's Avatar
scottlathrop
shadow sorry I was away. I made a clip fastened to the 1st piece with a hole for the screw. I had used FRP and it was too stiff for the factory clips to hold.
scott
Old Sep 13, 2014 | 01:27 PM
gangstakr's Avatar
gangstakr
Made my own. Made it to resemble the hood.
Old Sep 13, 2014 | 01:31 PM
scottlathrop
salf100 - I used FRP (F for fiberglass Reinforced plastic) its stiffer but unaffected by heat and will not sag here in Florida. I did not like the look when complete-sorta looked like a shower- so I went to Joanne fabric and bought headline fabric and spray glued it over the frp.
Old Sep 13, 2014 | 01:51 PM
scottlathrop
gangstakr- Again your work is unreal. If I get to CA I will look you up to see it first hand. I'm a dub and thought mine looked pretty good for my pay scale.
Scott
Old Sep 13, 2014 | 08:12 PM
gangstakr's Avatar
gangstakr
This is very nicely done. The extra screws on top are very much needed. With a headliner the inside just looks so much nicer. Good job.
Old Sep 15, 2014 | 08:41 PM
johaness_00's Avatar
johaness_00
Does anyone still have the pdf for the headliner. I have a 64 and trying to figure out what to do.
Old Sep 23, 2014 | 05:15 PM
rmk73's Avatar
rmk73
Good looking headliners guys! I have a question... With a black seat and ACC black vinyl flooring would you guys use a black headliner or grey?? Give me your opinions. Thanks
Old Oct 8, 2014 | 07:07 AM
  #28
black betty's Avatar
black betty
VERY NICE!!!!
Old Oct 8, 2014 | 08:45 AM
  #29
salf100's Avatar
salf100
I thought about using the heavy card board upolsters use for door panels etc and just paint it. Any thoughts?
Old Oct 11, 2014 | 12:04 PM
  #30
6t6merc's Avatar
6t6merc
Salf - I think the cardboard will not bend as you need it to in a few places. I am considering PVC sheet shower liner in a thickness of 1/16'' (or maybe 2mm). It is very strong yet will bend without cracking. I have a scrap that is very close to Wimbledon white and I'm looking for a local source for a 4x8' sheet of the same. I intend to use it for the door "panels" as well, so I want it to match the dash, although Ford didn't do too well on that issue originally...
Eric
