That's a secondary brake light switch and is a sign that your truck has or had cruise control. Trucks with cruise control had two brake light switches in parallel, each a different style ("plunger" and "mechanical"). Since the brake switch can shut off cruise control and is considered "mission-critical", having the two in parallel acts as a redundant safety feature. That's my understanding at least.
No part numbers marked on parts after 1956, just casting and ID engineering numbers, when applicable.
D5TZ-13480-A .. Stop Light Switch / Marked with ID engineering number: D5TB-13480-AA / (Motorcraft SW-1258).
Applications: 1975/77 F100/350 460 with Speed Control / 1978 F100/350 with Speed Control before serial number CG0,001.
With Speed Control, this switch fits onto a stud on the brake pedal, retained by a clevis pin (380699-S100), then to the master cylinder rod.
There are two nylon bushings on either side of the stud (C5DZ-2B129-B), another nylon bushing (C1TT-2B309-A) inside the master cylinder rod.
Lower left in pic.
Thank you sir.
SO from what I am gathering, Its a feature to release the cruise control when the brake is depressed...? I do know that when I push the brake pedal the brake lights come on...check....and the truck no longer has cruise control...check. So the chingadera is not mission critical?
Thank you sir.
On cruise control trucks, either switch (plunger or mechanical) can release cruise control, AND actuate the brake lights. They're in parallel.
If your brake lights work, the plunger switch is still there, so that's fine. If you no longer have cruise control, then you don't need the backup mechanical switch. Just tuck it up out of the way and you'll be good.
I appreciate the help.
I've been weeding through this truck trying to undo all of the redneck engineering the previous owner did. I don't think I am going to try to redo the power steering at this point so I will tuck it away as recommended. Thanks!
