Replacement radio
Old Jul 5, 2003 | 02:47 PM
302V8Ford79's Avatar
302V8Ford79
Replacement radio
I have a standard AM radio in my 79 F-100, and would like to upgrade to at least AM/FM, that or AM/FM CD. I would prefer not to do any metal cutting. Does anyone know where I could start looking for this?
Thanks.
Old Jul 5, 2003 | 04:12 PM
Mil1ion's Avatar
Mil1ion
Replacement radio
Without cutting you won't get a CD player in the radio spot.
You can get AM/FM radio stereo's or AM/FM Cassette
Old Jul 5, 2003 | 04:46 PM
Greg 79 f150's Avatar
Greg 79 f150
Replacement radio
Thank goodness your not a sawsall junkie . Thats what the previous owner on my truck used to put in a cd player. Luckily, he didnt get the metal dash, i just had to replace the plastic bezel. I put a am/fm cassatte in a 79 I had back in 84 without cutting anything, just had to make my own strap hanger in the back of the unit. Your local stereo shops should have something that will fit without maiming your Ford.
Old Jul 6, 2003 | 03:11 AM
clean79150's Avatar
clean79150
Replacement radio
I had cut mine years ago, and installed an AM/FM CD stereo. It will work, but you do have to cut the radio/heater control bracket, and then fab up a lower support for the heater controls. I've seen people do it without supporting the heater controls, but I felt better having a support piece in place.
It really isn't that bad, and it doesn't have to be permanent. you can buy the radio / heater support bracket on e-bay for about 8 bucks, that way you'll have it in case you ever want to go back to the shaft mount radio.
OR:
They make shaft mount cassette radios that have CD changer controls in them, and then put the changer behind the seat.
Old Jul 6, 2003 | 03:13 AM
Texan1983's Avatar
Texan1983
Replacement radio
just cut it out and put a much nicer standard CD player. much easier and nicer looking
Old Jul 6, 2003 | 06:02 AM
76supercab2's Avatar
76supercab2
Replacement radio
Classic auto sound has units that will fit without any cutting. I have one with remote cd changer control for my 72 mustang that I am very happy with. Their catalog lists mid 70's trucks as an application.
Old Jul 6, 2003 | 02:06 PM
F150daniel's Avatar
F150daniel
Replacement radio
radio
this place has that fit in stock holes
Old Jul 7, 2003 | 07:56 AM
78f250's Avatar
78f250
Replacement radio
Crutchfield has a Kenwood tapedeck (dual **** type) that will fit in with zero cutting.
Old Jul 7, 2003 | 10:34 AM
Henry_the_Ford's Avatar
Henry_the_Ford
Replacement radio
Any 2 **** radio/cassette will fit the hole and then you can attach a cd changer. Or if you go to any local radio install shop they should have an under dash mount for a DIN style cd player. The under dash kit will require you to put a couple of screw holes in the underdash metal though.
I worked in the Circuit City car stereo installation shop years ago when in college. We put a bunch of the under dash kits in. But for those that wanted the stereo mounted in the dash the 2 **** versions fit fine. Did a bunch of classic mustang installs with the 2 knobbers. As mentioned above Kenwood makes several nice ones.
Hank
Old Jul 7, 2003 | 11:48 PM
77f150351c's Avatar
77f150351c
Replacement radio
you know I cut mine and it was not a problem but if you really want a nice cd/am/fm radio you could take the mount that comes with the stereo and bolt it under the dash by the ash tray. then all you have to do is rip out the am radio that you have and put a piece of black plastic over the hole I have done this in a friends truck and it looked very professional.
Satch
1997 - 2003 F150
Jan 29, 2016 07:35 PM
79 f-150 guy
41
Oct 22, 2010 10:35 AM
evg1973
1983 - 2012 Ranger & B-Series
Aug 13, 2010 10:55 AM
Keystonepaul
May 17, 2010 08:51 AM
Thuner
Oct 3, 2007 05:58 PM
