Is there a way to adjust the power steering to make it a bit harder to turn? We have had two B2's and both have steered way to easy and it makes oversteering and easy thing to do. It could be half the power it is now and that woud suit me perfectly.
You may want to have the front end checked if you not aware what to look for
may be worn parts.There is an adjustment screw on your power steering pump for increased pressure sensitivity,but I must say I have never backed one off becuase of the situation you have discribed.
Are you running a lift ? and have bump steer or has the suspention be modified maybe just go get an alignment.
