To remove the steering wheel, back the nut off till it's flush with the end of the shaft, (I personally remove the nut) then with a good heavy hammer, not a sledge just a heavy hammer, smack the end of the shaft hard. work the nut in and out a little, just to make sure the threads are still good. Then back it off more or remove, smack it again if necessary.
I can usually remove them with one hit with my small but heavy ball pin hammer.
Your steering wheel should now come off.
