Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Electrical Help?
Old Apr 26, 2014 | 08:04 PM
F0rdE$cape's Avatar
F0rdE$cape
Electrical Help?
Just had transmission rebuilt, which works great by the way, and on the drive home I noticed certain items were not working like the clock radio was not lit up nor would it turn on. Checked radio fuse and it was good. My key fob would not work to unlock or lock the doors. The power locks will only work with key turned to accessory or on and the dome lights do not work at all. The theft light is no longer blinking as well and my headlights that use to turn off after a 3-5 minute time delay now turn off as soon as I turn off the ignition. Any ideas that I could trouble shoot before I take it back Monday for the transmission shop to check for something they left unhooked.
2002 Ford Escape 3.0 XLT 4x4
Old Apr 27, 2014 | 07:12 AM
projectSHO89's Avatar
projectSHO89
Sounds like one of the fuses that is supposed to supply the GEM module isn't.
Check F20 under the hood and fuses F11, F26, F27 ( all three are always hot), F8 (hot in accy or run) and F16 (hot in start or run), all in the under dash fuse box.
If one is found to be blown, and, if you replace it, it blows again, be sure to identify the specific fuse by its designator. It's probably one of the always hot fuses.
Old Apr 27, 2014 | 10:20 AM
F0rdE$cape's Avatar
F0rdE$cape
Thanks for the advice. I assume these fuses will be identified as such F20, F11.... Etc
Old Apr 27, 2014 | 12:18 PM
projectSHO89
Look in the owner's manual.
Old Apr 27, 2014 | 06:22 PM
F0rdE$cape's Avatar
F0rdE$cape
Thanks for the help, it was F27 blown
Bmanwplan
Sep 8, 2021 10:58 AM
verbal kint
Sep 29, 2010 03:11 AM
first_f250
Aug 10, 2009 06:54 PM
triskit16
Apr 21, 2009 11:17 PM
tatetodd
Electrical Systems/Wiring
Sep 18, 2006 05:58 PM
