94 F150 starting issues
Old Apr 25, 2014 | 11:42 PM
Will5o5's Avatar
Will5o5
I have a 94 F150 with a 302, 140k miles. The truck used to fire up with a tap of the key, now it has to be cranked anywhere from 3-5 seconds. It seems to help if I bump the ignition a few times, then it won't crank and it fires up like it used to. It runs completely fine, seems like the idle is getting a little rough though. Changed the plugs, fuel filter, battery. I don't think it's a fuel issue because it does it randomly hot or cold on either fuel tank and even after priming the pump by cycling the key a few times. Any advice would be helpful, don't feel like replacing a starter, thanks..
Old Apr 26, 2014 | 11:40 AM
RIKIL's Avatar
RIKIL
Pull the codes for starters.
Also might have better visibility with this thread in the 87-96 forum
Old Apr 26, 2014 | 11:51 AM
Will5o5's Avatar
Will5o5
Thank you sir, I got it up over there.. This OBD1 system will pull codes for starter issues??
Old Apr 26, 2014 | 11:55 AM
RIKIL's Avatar
RIKIL
There can be a few issues causing this and depending on what it is, a code may be in the computer
Kbdf150
Sep 16, 2016 06:04 PM
rbr658
Sep 11, 2015 02:29 PM
Will5o5
Apr 26, 2014 04:14 PM
oudeisman
2004 - 2008 F150
16
Jul 14, 2011 08:15 AM
ChargerFan
Oct 6, 2004 07:31 PM
