Climate Control Screen goes blank
Old Apr 24, 2014 | 01:53 PM
rowekmr's Avatar
rowekmr
I had this happen once and nothing I did would get the heat to come on and it was cold outside. I ended up turning truck off then back on and it worked. Anyone knows what causes this?
Thanks
Old Apr 24, 2014 | 02:01 PM
rlittlep's Avatar
rlittlep
5A Memory fuse, not sure what position off hand..
Old Apr 24, 2014 | 02:19 PM
RobRoss's Avatar
RobRoss
Seems to happen on the diesel trucks. I had an 04 with a 6.0L and it would blank out every now and then. The next time I started the engine it would come back. I've read where some have cycled the headlamp switch and got ti work again. It's pretty common.
Old Apr 24, 2014 | 02:24 PM
Stewart_H's Avatar
Stewart_H
Excursion tech folder.
Interior > Electrical
Click the thread and scroll to post #6.
Stewart
Old Apr 24, 2014 | 02:27 PM
Misky6.0's Avatar
Misky6.0
answer is…
turn on your headlights - it'll trip the sticking 'non replaceable' relay on the back of the instrument cluster and wake up all the things in power-save mode.
Old Apr 24, 2014 | 04:09 PM
rlittlep's Avatar
rlittlep
Replace the ATC unit...........If the Fuse{Memory} is OK?
1ole4d
Apr 27, 2018 11:04 AM
slenser
Sep 5, 2011 08:30 PM
foul1
Jan 26, 2010 09:49 PM
Headviking
Jan 26, 2010 07:28 PM
bpounds
Oct 15, 2009 08:04 PM
