Brake and steering making throbing noise - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 03-14-2018, 01:51 AM
gbaumgar1
gbaumgar1 is offline
gbaumgar1 is starting off with a positive reputation.
So here is the scenario.. I parked the truck for about 3 months and then fired it back up (Fired right up after sitting under 2 feet of snow in Fairbanks Alaska&#128512. But, All of a sudden I have a weird tapping sound and feel in the steering wheel and brakes. It did not do that when I parked it. I'm going to post a video for you to hear and see. I haven't run in to this before so hoping one of you knows what the problem is.
Old 03-14-2018, 02:19 AM
StrokinHer01's Avatar
StrokinHer01
StrokinHer01 is offline
StrokinHer01 is starting off with a positive reputation.
That sounds like abs.. I like to mess around in the snow and get sideways in my truck and when I press the brakes the anti lock makes that weird noise (not all the time just on slippery surfaces)...or power steering which is ran by the serpentine belt which the motor gives more rpm which may be why you hear it when you rev... either abs or power steering just a thought...
Old 03-14-2018, 06:35 AM
Sous's Avatar
Sous
Sous is online now
Sous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant future
Sir, you are in luck! I was the first one on FTE (as far as I know) to have this issue as well. See the thread and video below for details.
Thread with attempted fix actions and the final step.
https://www.ford-trucks.com/forums/1...ide-fixed.html
94CrismonRedXLT
05-21-2010 08:55 AM
clearwire44
07-30-2007 09:31 PM
Big Red
05-10-2006 09:52 PM
swirk
12-12-2002 04:21 PM
redneckdieselmechanic
07-23-2002 02:04 PM
Quick Reply: Brake and steering making throbing noise
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
