troubleshooting 4wd issue
Old Apr 24, 2014 | 09:00 AM
Execut1ve's Avatar
Execut1ve
Hello all,
1994 F150 302 4R70W
auto hubs
electronic shift
Borg-Warner 1356 tcase
I am seeking advice on troubleshooting a 4wd issue I am having. Currently the truck will not shift into 4wd at all. When I press the button, I hear the usual clicking from under the right side of the dash, but 4wd does not actually engage, nor does the 4wd light illuminate.
I detached the shift motor from the tcase. A small amount of liquid came out when the motor was removed. Is that normal? I had an assistant sit in the truck and press the button while I observed the detached (still connected to wiring harness) motor beneath. The motor jerked a couple times, but did not actually turn. The rhythm of the jerking was the same as the clicking heard under the dash.
At this point I don't know if the shift motor is bad, or there is a connectivity issue in the harness somewhere. Any advice or suggestion is appreciated.
Thanks!
Old Apr 24, 2014 | 09:54 AM
Conanski's Avatar
Conanski
Shift motor is bad.
Old Apr 24, 2014 | 10:24 AM
Execut1ve's Avatar
Execut1ve
any way I can verify that the shift motor is the problem before I throw down $80+ on a new one?
Jack Peterson
Dec 27, 2016 12:51 PM
BII Plow Truck
2004 - 2008 F150
Jul 7, 2011 01:23 PM
snoVVman
Jan 29, 2006 07:55 PM
91 Explorer
Nov 27, 2004 11:56 AM
ekombeer
Offroad & 4x4
Apr 8, 2003 04:47 PM
