91 Explorer 4WD Electric Shift wont work
Old Nov 26, 2004 | 09:16 PM
91 Explorer's Avatar
91 Explorer
I just purchased a 91 Eddie Bauer Explorer from a friend who had it for many years. After purchase I tried to engage the 4WD with the button on the dash and it seems to do nothing. My friend said it worked last time he tried it but that was over a year ago. I checked fuses and they were fine...so I came straight to this site for help. I found what appears to be the reset button in the rear by the washer fluid tank and now the red light on that box comes on with the ignition. Still no 4WD... I tried to link to the glue.umd.edu site that is referanced in earlier forums but it says that I am denied access. Can someone please tell me what my next step is to solve this problem with my Electric Shift???
Old Nov 26, 2004 | 10:33 PM
mrshorty's Avatar
mrshorty
Sounds like the typical dirty shift motor issue that's so common on these. The shift motor gets dirty and can't move the shift fork.
This assumes that the t-case isn't engaging. About 1/2 of the "no 4WD issues" are bad auto hubs, so you might take a couple of minutes and verify the t-case isn't engaging.
Old Nov 27, 2004 | 08:21 AM
91 Explorer
Thanks for the information.....I will take a look at that motor on the transfer case this morning.
Old Nov 27, 2004 | 11:56 AM
91 Explorer
Smile
I just finished taking the shift motor off and went through it....not very dirty but it resolved the problem. Both 4wd High and Low work now!!! Thanks for the help!!!!
23racer
Dec 10, 2013 05:01 AM
Redfridge
New Member Introductions
Oct 24, 2013 10:13 PM
MikeVelilla
Aug 25, 2013 10:18 AM
fordgta
Electrical Systems/Wiring
Jan 17, 2005 06:12 PM
