Sponsored by: Real Truck
Snap ring from Hell
Old Apr 24, 2014 | 04:45 PM
MisterCMK's Avatar
MisterCMK
Did you install the seal before putting the axle shaft back in?
Sent from my Telegraph using IB AutoGroup
Old Apr 24, 2014 | 08:01 PM
1977cutcher's Avatar
1977cutcher
Dido. The seal is installed on the shaft before re assembly. It is a pain in the rear. I used a piece of 3 inch PVC to go around the seal. I put a board on top of the pipe to get a good solid even hit. A little silicone may help, the problem is that it is a tight fit and really hard to get started. I used a copious amount of foul language, not sure if it helped or not though.
Old Apr 24, 2014 | 08:13 PM
MisterCMK's Avatar
MisterCMK
I put the axle shaft in the vise and then just hit the seal driver tool with a good sized hammer and it goes right on.
Old Apr 24, 2014 | 09:07 PM
1977cutcher
I am interested in the seal driver tool, can you post a picture?
Old Apr 24, 2014 | 09:46 PM
MisterCMK's Avatar
MisterCMK
It looks like this:
bruno2
Apr 23, 2017 01:29 PM
Billyclub
15
Jul 10, 2016 07:33 PM
GetSmoke
Jan 23, 2011 12:24 PM
Orezona
Nov 19, 2006 08:04 PM
Mac 25
Aug 23, 2005 11:28 AM
