Sponsored by: Real Truck
Axle Snapring...PITA
Old Jan 22, 2011 | 06:29 PM
GetSmoke's Avatar
GetSmoke
I just replaced ball joints, all axle seals, installed axle, greased hub and bolted it on.
I went to put the washer, "nut", washer, then snapring and the groove is not out far enough to fit snapring in.
If I removed one of the washers or that "nut" I could get it with no problem.
Should I...
Remove a washer.
Place snapring on outside of groove...it's pretty snug.
Take hub off and pry axle forward.
Any other suggestions.
Old Jan 22, 2011 | 08:05 PM
wideglidewoody00's Avatar
wideglidewoody00
I have a 04 with the esof and to put the snap ring on I had to pry the stub axle out from the back and the snap ring popped into the groove.
Old Jan 22, 2011 | 08:16 PM
GetSmoke's Avatar
GetSmoke
I'll give it a shot.
Did you have to remove the hub or did you leave it in place?
Old Jan 22, 2011 | 08:40 PM
elee3's Avatar
elee3
You shouldn't have to remove anything, you can just put a pry bar between the axle housing and the CV joint and move it enough to get the snap ring in.
Old Jan 22, 2011 | 08:58 PM
1975StroppeBaja's Avatar
1975StroppeBaja
BINGO! That's what I had to do too.
Old Jan 23, 2011 | 12:24 PM
wideglidewoody00
Cool, Glad it worked out for you!
King-bRanch
Sep 7, 2015 11:10 PM
Rustyblue
Jul 14, 2012 12:06 AM
yasky69
Modular V10 (6.8l)
30
Jan 22, 2011 09:35 PM
jlegge007
Jun 20, 2007 11:59 PM
