I've been experimenting with Torque Pro and an OBD2-Bluetooth adapter.
To the FTE Torque fans: do you know if it's possible to create a custom gauge that collates/compares data from multiple sensors?
What I would like to do is create a custom gauge that reads both the ECT and the EOT and displays the delta. I'd like to set it to alarm if the delta exceeds fifteen degrees.
I can keep an eye on the two myself, but it'd be a lot easier if Torque could just alert me when the delta exceeds a certain threshold.
Also: is there a sensor for EGT on the 6.0, or do I have to add one?
