Dropped driveshaft
Old Apr 22, 2014 | 05:48 AM
bonedoctor's Avatar
bonedoctor
Dropped driveshaft
Good morning everyone,
My Excursion has a 5" Superlift 35" tires. Runs and drives great. The front is a full spring lift, the rear is a 5" block. No vibrations or apparent issues.
Put the truck in reverse last night and had to step on the gas fast and hard and bang, the rear driveshaft dropped. The slip joint separated and torn the boot. It appears that there is no other damage. My guess is when I torgued it hard in reverse the pinion dropped, the rear tires flexed the axles backwards and it was just enough to disengage the slipjoint splines.
Anyone hear of this or have this happen? I'm figuring the driveshaft probably needs to be lengthened an 1", maybe 2" but want some input.
This truck is a pavement queen and family hauler. I'm happy with the suspension set up as it rides really nice, I don't want to swap in stiffer springs.
Any suggestions?
Thanks
Old Apr 22, 2014 | 05:57 AM
bonedoctor's Avatar
bonedoctor
I've done some looking and I'm wondering if it isn't my Driveshaft but rather my rear leaf springs being worn out and too soft, then add the leverage that the axle with 5" blocks have and BAM!!! No wonder it separated.
Old Apr 22, 2014 | 06:05 AM
hav24wheel's Avatar
hav24wheel
With that lift, the rear shaft prob should be lengthened. The lift block does let the axle "walk" around under there a bit. A traction bar would help, or get lift springs to replace the blocks.
Old Apr 23, 2014 | 11:38 PM
X-Hibition's Avatar
X-Hibition
I've got five inches of all spring lift and have never had this issue. You may be correct about the springs and block...
Dutter 2
21
Dec 30, 2014 10:30 PM
Firewhoop3
1997 - 2003 F150
Dec 3, 2011 07:50 PM
blackx psd
Mar 25, 2011 04:46 PM
Mat J
May 5, 2010 07:31 PM
Nite Bronco
1978 - 1996 Big Bronco
Apr 3, 2003 10:10 PM
