If you are going for the best price use the one you found. The shielded one cost almost 2.5X the price.
Replace your ball joints and the upper joint bushing/eccentric, if you want to adjust camber, and replace the axle u-joints and every thing you want to rebuild while you are in there so you will not have to replace the knuckle seals again just to go in again.
The seal I found on Amazon "will" work? You mentioned it was the wrong one a post or so back.
Also,I use amazon.com and orilley.com to search for fitment by a specific vehicle to confirm aftermarket parts match factory parts. look in details section of description for compatible part numbers. Amazon much cheaper for exact same parts as O'Rilleys
