Sponsored by: Real Truck
Need some front end help please
Old Apr 21, 2014 | 07:36 PM
joe blow's Avatar
joe blow
Hi,
2004 PSD 4x4 72k.
I thought I would be proactive so I bought the front ball joints and have plans to install them but recently I starting hearing (and feeling) a clicking sound in the front LEFT when I make sharp turns to the left and hit small bumps now and again. I jacked up the front end and am able to get 1/4" of movement front to back (top to bottom so not steering) in the wheel. I narrowed it down to the hub. I took it apart and it is most likely a sealed unit so no adjustment is possible....that I can see.
I pulled out the locking hub and got as far as I can to know there is not an adjustment.
Can someone please confirm that it indeed is a sealed bearing and if so guide me in the right direction as to the part number(s) I may need to repair it.
Thank you very much for the help
Joe
Old Apr 21, 2014 | 08:39 PM
99f350sd's Avatar
99f350sd
Yup sealed bearing..Go to your fav parts store or online and get a new unit.
You will need 2 seals. There is a thread on here about balljoints. Shows how to do everything.
http://www.superdutypsd.com/ball_joint_article.php
Racerguy has a good article on here also...Make sure parts are for your year..
Old Apr 21, 2014 | 11:16 PM
joe blow's Avatar
joe blow
Cool thank you brother!
Reps to ya
Old Apr 22, 2014 | 07:24 AM
jesse5's Avatar
jesse5
SKF Part Number: BRG BR930438 at Napa.
Old Apr 22, 2014 | 01:24 PM
joe blow's Avatar
joe blow
Is SKF a brand? Not familiar with it
Thanks
Old Apr 22, 2014 | 01:28 PM
jesse5's Avatar
jesse5
Yes, a good one if you are not going with an OE part. The other brand name is Timken and it is available at AutoZone.
Old Apr 22, 2014 | 09:56 PM
joe blow's Avatar
joe blow
Thanks jesse. I am familiar with Timken but not the other...thank you for the help.
Old May 1, 2014 | 06:09 PM
joe blow's Avatar
joe blow
Had a chance to look stuff up and now I am like WTF?!
I called FORD and gave the guy my VIN since there are variations in wheel hub assy's.
The dude gave me the part number F81Z1104BA but he reiterated the threads were coarse.....I am pretty sure my threads are the 8x170mm pattern and fine
The other part number he gave me before I gave him my VIN is 3C3Z1104BA- which is a fine thread stud.
Can anyone please help me with this problem that is starting to make me crazy. Maybe I am fkd up and I thought I knew the difference between coarse and fine
I want to order a TIMKEN or SAF brand but I need to make sure I order the right one.
Old May 1, 2014 | 06:28 PM
je5's Avatar
je5
Your threads are fine.
Old May 1, 2014 | 06:32 PM
je5's Avatar
je5
The change from course threads was at the end of model year 2002.
Old May 1, 2014 | 10:05 PM
joe blow's Avatar
joe blow
Thank you....here are the two I am considering. Which would you choose if they were priced the same....which they aren't
More Information for TIMKEN SP580205
$171.00
More Information for SKF BR930438
$259.00
Thanks
Old May 1, 2014 | 10:19 PM
je5's Avatar
je5
I looked at both of your link's and the SKF had three times the warranty. You could try one of each and form your own opinion. I have used both.
Old May 1, 2014 | 10:32 PM
joe blow's Avatar
joe blow
Yeah I was thinking about dropping the extra money for the SKF brand. To be honest I have never heard of SKF until you brought it to my attention. TIMKEN I have heard of and used but limited to bearings and races....not full blown wheel hub assy's.
You mentioned you used both.....which did YOU prefer/ had better service life with?
....and since you have a great understanding of what I am doing can you confirm this is the axle seal I need (or do I need the more expensive w/ dust shield)
Amazon.com: SKF 28600 Axle Shaft Seal: Automotive Amazon.com: SKF 28600 Axle Shaft Seal: Automotive
Thanks for helping me out ( REPS to you by the way)
Joe
Old May 1, 2014 | 11:47 PM
je5's Avatar
je5
I like factory parts if price is of no concern.
Not the exact knuckle seal but will work. Use Motorcraft and install with a driver you make or the special tool, they are too expensive to bind. Dealer will install for cheap usually if you carry axles in.
"The original 1st design knuckle seal design is unshielded and was used from 1999 to early 2002. A 2nd design, redesigned seal with a shield on the inboard side was introduced in 2002 calendar year as a 2003 model year part. The early seals will work on all 1999-2004 Super Duty's. The later shielded seal will only fit outer axles with a step diameter of approximately 3.115". Most trucks built prior to mid 2002 will have outer shafts with a step diameter of 3.210" which will not accept the shielded seal."
Old May 2, 2014 | 12:07 AM
joe blow's Avatar
joe blow
Wrong knuckle seal. Use Motorcraft and install with a driver you make or the special tool, they are too expensive to bind. Dealer will install for cheap usually if you carry axles in.
Got it....The OEM versions are too Fkng expensive so I think the SKF is the next better choice.
So now that my head is spinning .....with that said regarding the seals....any chance you know or can help me with the part number or link or..... for the seals I need? The guy at the dealer gave me F81Z1S175HCA @ 31.63 A PIECE using my VIN.....but then again he is the same ding dong that told me I had course threads according to my VIN.
Thanks for the help!
Joe
